re using valley pan 440? #1451203
06/11/13 10:56 AM
06/11/13 10:56 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
my valley pan is fel pro i believe and has been used once. i know the embossing around the ports is crushed but can you reuse with some hylomar spray or copper coat around the ports? i need to save everywhere i can to get this hunk running again! thanks
74 dart sport 440 www.Csucarbs.com
Re: re using valley pan 440? [Re: shoebox] #1451204
06/11/13 11:55 AM
06/11/13 11:55 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I reuse them many times. little sealer or use intake gaskets with it.
Re: re using valley pan 440? [Re: VernMotor] #1451205
06/11/13 02:50 PM
06/11/13 02:50 PM
Me too Hylomar and thin gaskets are your freind
Re: re using valley pan 440? [Re: Cab_Burge] #1451206
06/11/13 02:55 PM
06/11/13 02:55 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Many times here also!
And I make the thin .015" gaskets for that
http://www.superformanceproducts.com/
Re: re using valley pan 440? [Re: shoebox] #1451207
06/11/13 04:20 PM
06/11/13 04:20 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
SAME intake and SAME heads ?....with a little copper-coat ?? ... no problemO !
