Stupid me...new floor pan in my b body and all mounting holes for the seat belts were in the new pan. Or at least I assumed...finished up the interior, installed seats and mounted the rear seatbelts, then got to the front and mounted the floor tunnel-lap belts. Went to mount the retractors on either side of the bench seat and alas, no holes...should have noticed before but didn't.
What are my options? I've done a search and there's mounting kits that use nuts/bolts and backers that look fairly easy to install, but is that a good idea?
Any help is appreciated!
Thanks.
