mopar performance roller rocker question stage IV #1450628
06/10/13 04:30 PM
06/10/13 04:30 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
im interested in buying a new old stock set of mopar performance "crane gold" roller rockers for my 440. there were 3 part numbers one was 1.5's the other 1.6'a and another number 1.5s but for stage 4 and 5 heads. will they work on stock heads? i believe the intake rocker adjuster is moved away from the port only. not the exh rocker
74 dart sport 440 www.Csucarbs.com
Re: mopar performance roller rocker question stage IV [Re: shoebox] #1450629
06/10/13 05:00 PM
06/10/13 05:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The Stage IV rockers will work on the other OEM 906/452/etc. castings, since those heads have plenty of room for the intake pushrods to be offset away from the port due to the way the heads are cast.
Re: mopar performance roller rocker question stage IV [Re: BradH] #1450630
06/10/13 06:09 PM
06/10/13 06:09 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
cool i hope my stealth heads have the same clearance..
Re: mopar performance roller rocker question stage IV [Re: shoebox] #1450631
06/10/13 10:58 PM
06/10/13 10:58 PM
BradH Offline
BradH  Offline
Nope, because the Stealths are filled in where the OEM iron heads are wide open. Not likely to work w/o some MAJOR pushrod tunnel , I'd expect.
