What specific oil to use 440 Valvoline VR1 Racing Oil #145057
11/03/08 12:58 PM
11/03/08 12:58 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
I am trying to buy 6 quarts of Valvoline VR1 Racing Oil to change the oil for the first time in my 440, but which of the following specifically?
Valvoline Racing VV205
Valvoline VR1 Racing Oil 10W30 weight 1 quart
Item# 949-VV205
Only $4.99
Valvoline Racing VV211
Valvoline VR1 Racing Oil 20W50 weight 1 quart
Item# 949-VV211
Only $4.99
Valvoline Racing VV851
Racing Conventional Motor Oil 20W50 Weight
Item# 949-VV851
Only $9.99
Valvoline Racing VV223
Valvoline VR1 Racing Oil 30 weight 1 quart
Item# 949-VV223
Only $4.99
Valvoline Racing VV850
Racing Conventional Motor Oil 10W30 Weight
Item# 949-VV850
Only $9.99
Valvoline Racing VV235
Valvoline VR1 Racing Oil 50 weight 1 quart
Item# 949-VV235
Only $4.99
Valvoline Racing VV855
Racing Synthetic Motor Oil 20W50 Weight
Item# 949-VV855
Only $11.99
Valvoline Racing VV854
Racing Synthetic Motor Oil 10W30 Weight
Item# 949-VV854
Only $11.99
Valvoline Racing VV229
Valvoline VR1 Racing Oil 40 weight 1 quart
Item# 949-VV229
Only $4.99
Valvoline Racing VV852
Racing Conventional Motor Oil 50 Weight
Item# 949-VV852
Only $9.99
Valvoline Racing VV831
High Performance Gear Oil 80W90 Weight
Item# 949-VV831
Only $6.99
Valvoline Racing VV853
Racing Synthetic Motor Oil 5W30 Weight
Item# 949-VV853
Only $11.99
Valvoline Racing VV360
Valvoline Mercon V Auto Trans Fluid Synthetic 1 quart
Item# 949-VV360
Only $7.99
Valvoline Racing VV241
Valvoline VR1 Racing Oil 60 weight 1 quart
Item# 949-VV241
Only $4.99
Valvoline Racing VV825
High Performance Gear Oil 80W140 Weight
Item# 949-VV825
Only $6.99
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: AHall] #145058
11/03/08 01:15 PM
11/03/08 01:15 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
ttt
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: AHall] #145059
11/03/08 01:58 PM
11/03/08 01:58 PM
i use
Item# 949-VV211
Only $4.99
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: AHall] #145060
11/03/08 02:09 PM
11/03/08 02:09 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Just a stab in the dark without any info to make an informed choice,but I'll take #1 or #5 .
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: goldmember] #145061
11/03/08 02:55 PM
11/03/08 02:55 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
From what I have been told, the VR-1 20W-50 in the silver bottle is a good off the shelf oil for use in above freezing temps. My understanding is that the other "Valvoline Racing" (non-VR1) oils in the black bottles are non-detergent oils. Their intent is that they are in the car for a short period of time, like a race weekend, then changed. Because they lack a detergent as part of the additive package, they have a very short life cycle on the street. The Porsche engine builder I spoke with thought you "might" get 1000-1400 miles out of it before he'd recommend changing it for sure. In general, he advised against using Racing Oils for a traditional 3000 mile drain interval.
Brad Penn brand also seems to be a name that keeps coming up as a good oil.
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: AHall] #145062
11/03/08 03:18 PM
11/03/08 03:18 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Up in the great white north I would go with VV850 in winter and VV851 in summer.
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: Lefty] #145063
11/03/08 03:29 PM
11/03/08 03:29 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Just to be clear, those two are the black bottle non-detergent oils which are said to have a shorter drain interval. The bottles are marked "Not Street Legal"
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: Aero426] #145064
11/03/08 03:32 PM
11/03/08 03:32 PM
Lefty Offline
Lefty  Offline
Is it possible to get enough zinc AND detergent with VR1?
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: Lefty] #145065
11/03/08 03:36 PM
11/03/08 03:36 PM
i called their tech line and they said they do have sufficient quantities of both. drain interval in 3 months/ 3000 miles.
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: Lefty] #145066
11/03/08 03:36 PM
11/03/08 03:36 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Yes. VR1 has the Zinc package with a detergent. Their web page specifically calls it out as OK for street use.
They separate what they call "conventional oil" from VR1 in the silver bottle here. The VR1 is still a dino oil. Here's the link. Valvoline Racing Oil Page
Also here is the link for their Zinc FAQ page.
Valvoline Answers About Zinc
For a car with no converter, another good option if you can find it is a 15W-40 diesel oil that is rated CI. Stay away from the newer CJ diesel oils.
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: Lefty] #145067
11/03/08 03:48 PM
11/03/08 03:48 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
One more thing. If you've been running a non-detergent oil for an extended period of time, keep running it. Don't switch as the detergents will tend to put all the nasty stuff in suspension.
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: Aero426] #145068
11/03/08 05:05 PM
11/03/08 05:05 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I sent in two samples (one new and one used) of Valvoline VR1 20w-50 racing oil for analysis at the local Caterpillar oil lab. This is thier SM rated oil, part number 211 that they claim has extra zinc.
Results for the new oil sample in ppm
Al-0 Ca-2121 Cr-0 Cu-0 Fe-1 Pb-0 Mg-21 Mo-0 P-1049 K-5 Si-4
Ag-1 Na-0 Sn-0 Zn-1182
The used oil sample had Zn-1172
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: Azzkikrcuda] #145069
11/03/08 06:31 PM
11/03/08 06:31 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
The oil guy that talked to us the other night is big on oil analysis. His suggestion was to always send a control sample along with your current one, so you know what you are getting back. He gets good results from using Stavely for his analysis work. If you send a known second sample and it comes back vastly different from the first time, you know something may not be right, and you may need a retest.
When you look at the high reading for Ca, that must be the calcium as part of the detergent package.
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: Aero426] #145070
11/03/08 07:13 PM
11/03/08 07:13 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Non detergent oils are no big deal in a hobby engine. I dont have the number handy, but I run the straight 30WT "not for street use" VR1. It costs me like $8/qt, and has zink over 1300ppm iirc.
Re: What specific oil to use 440 Valvoline VR1 Racing Oil [Re: Aero426] #145071
11/04/08 03:11 PM
11/04/08 03:11 PM
Lefty Offline
Lefty  Offline
My newly rebuilt 440 in the Coronet was very clean I thought. After running 15-40 Lubrication Engineers diesel oil, the rockers and top of the head is cleaner than I have ever seen in a motor. Everything looks like it has been cleaned with 0000 steel wool and penetrating oil.
