I drove my Barracuda straight into a curb while having too much fun
and now the wheels are way out of alignment. There is definitely some toe out on the passenger side and a little toe in on the driver's side but what worries me is the extreme negative camber. If I jack up the car and set it back down the wheels will straighten up and sometimes if I drive it in reverse a little they will straighten up. But then if I drive it around the block they will work their way back to negative camber. I took it to an alignment shop but they wouldn't mess with it, mainly because they couldn't get it on the ramps because it sits too low with the hotchkis subframe connectors. I've checked it out underneath and nothing looks bent or broken but I've never messed with suspension so I'm at a loss. If anyone has some idea on how to adjust the camber I would appreciate any help or advice. Thank you.
