72 Cuda front disk brakes
#1449920
06/09/13 12:32 PM
06/09/13 12:32 PM
Posts: 1,487 STL
cdstl
STL
I replaced the brake lines, master cylinder, calipers and pads last winter. I used some disk brake lube on the backs of the pads and also on the pins that hold the assembly together. I have the retaining clips that hold the outer pad against the caliper assembly installed. No air in the lines.
It doesn't appear that the outer pads are contacting the rotor while the inners are doing their job.
Should I clean the lube off of the slides?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 72 Cuda front disk brakes
[Re: cdstl]
#1449921
06/09/13 01:11 PM
06/09/13 01:11 PM
RapidRobert
You wouldn't want to use enough lube to where it might splatter & contact the friction surfaces (rotor face/pad friction material) but I'm not sure what's going on
[Re: cdstl]
#1449923
06/09/13 03:10 PM
06/09/13 03:10 PM
Posts: 1,487 STL
cdstl
STL
I just decided to clean rods that the calipers slide on, pulled the rubber grommets out and cleaned them too. Slapped it back together and we'll see.
I've been using this stuff on disk brakes for a while. A little on the back of the pads, helps with squealing, and a little on the pins and it seems to work fine. I wasn't sure about using it on this rig but I did anyway.
