arrow drag cars #1449813
06/09/13 10:52 AM
06/09/13 10:52 AM
No. cal., sacramento usa
speedy383 Offline OP
Do these cars stop well with the original disc brakes and 10" rear drums. Plan is to run d gas (10.60)120/123 mph. This car has the stock wheelbase. Its backhalfed with full cage, Car weights 2500 w 200lb driver.
Re: arrow drag cars [Re: speedy383] #1449814
06/09/13 12:43 PM
06/09/13 12:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I can't answer that question, but is the car the old "Joint Venture" Arrow from Maryland? Mostly blue & red last time I saw it.
Re: arrow drag cars [Re: topside] #1449815
06/09/13 06:10 PM
06/09/13 06:10 PM
The one i am buying is in Colorado,no significant history ,old style bracket car,But has a very nice cage which will certify and some decent workmanship. But the front end has the stock struts and 4 bolt original type discs.I will probably rework the front suspension and maybe stretch the wheelbase some.
Re: arrow drag cars [Re: speedy383] #1449816
06/09/13 10:20 PM
06/09/13 10:20 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I stopped mine at 2300# running low nines at close to a 150mph with Dana drums and Mustang II discs up front. Stops WAY better with Wilwood on all four corners..
5.53 @ 125 1/8th on the launch control..more left in her!
