Small block valve spring dia.?
#144974
11/02/08 10:08 PM
11/02/08 10:08 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
I'm thinking of doing a cam swap in my LA,Are there any springs made that will handle .510 lift and fit the stock dia.spring pockets on these (360 915 J)Heads? Will the stock guides need to be cut for clearance? Just trying to save some $$$ and time by swapping them with the heads on the car.Thanks,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: Small block valve spring dia.?
[Re: bigD]
#144975
11/02/08 10:18 PM
11/02/08 10:18 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
dunno, but I think the spring pockets are in the 1.45" OD range...check out the diameter of a comp 901. those drop on w/o machining, but are only good to ~.490 lift.
[Re: Dartcuda]
#144977
11/02/08 11:11 PM
11/02/08 11:11 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
check out hughesengines.com
part number 1110
120# @ 1.660" Installed 310# @ .550" Lift Coil Bind: .620" lift Outer Spring ID/OD: 1.033"/1.440" Type of Spring:Single w/ damper
$5.50 each
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
