Easy e-body rear end question for sombody. #1449645
06/09/13 01:39 AM
06/09/13 01:39 AM
Poplar Bluff, Missouri
S&J Butler Offline OP
On a 70 Challenger where does the passenger emergency brake cable mount? There is a bracket welded in the rear "hump". Does it bolt to this or does it go somewhere else?
Scott
1970 Challenger
1973 Satellite 400
1974 Barracuda
1988 D-150 (LE-150) SWB
2010 Crew cab Hemi Ram
2019 Crew cab Hemi Ram
Re: Easy e-body rear end question for sombody. [Re: S&J Butler] #1449646
06/09/13 04:17 AM
06/09/13 04:17 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
P/S cable runs above axle near floor board & fastens to that bkt. near the D/S rear seat. Then continues to leftside & gets fastened to the 2 hole bkts. on rear of D/S rocker panel.
It's a reasonably longer cable then the D/S.
Re: Easy e-body rear end question for sombody. [Re: PhillyRag] #1449647
06/09/13 01:09 PM
06/09/13 01:09 PM
Thanks. That's where I thought it went but I wanted to make sure.
1970 Challenger
1973 Satellite 400
1974 Barracuda
Re: Easy e-body rear end question for sombody. [Re: S&J Butler] #1449648
06/10/13 12:42 AM
06/10/13 12:42 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
..And the rest of the routing..
