Interior Buzzing 73 Challenger #1449351
06/08/13 02:51 PM
06/08/13 02:51 PM
London, England
JFChallenger440 Offline OP
London, England
Hi guys i've got an annoying buzzing noise coming from the interior on my 73 Challenger, passenger side, it only happens above 40mph, any ideas ? Thanks
Re: Interior Buzzing 73 Challenger [Re: JFChallenger440] #1449352
06/08/13 03:31 PM
06/08/13 03:31 PM
Speedometer I would think. Might disconnect the cable from the speedo head & retry
Re: Interior Buzzing 73 Challenger [Re: JFChallenger440] #1449353
06/09/13 04:26 AM
06/09/13 04:26 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Mine does it also. Found out the freah air door foam has rotten away & door 'rattles' on opening, but only when closed & at higher speeds. But no noise if opened.
Easy to replace; if you don't mind removing the heater box
