Re: 93 Cummins trans slips in and out of overdrive
[Re: Rhinodart]
#1448562
06/06/13 07:56 PM
06/06/13 07:56 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
could be a TPS problem or a OD sol problem VSS problem or internal pressure problem. Would have to put it on a scanner and look at data to see what's going on.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: pinkduster]
#1448565
06/06/13 08:19 PM
06/06/13 08:19 PM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
Simply unplug it and plug it back in again. This might be a quick "on the road" fix for you and has worked for me MANY times. I assume the slightest bit of green stuff type corrosion can mess up the signal. Sometimes just striking a new connection can clear it up. Sometimes you have to use spray electric parts cleaner and dielectric grease to get it working properly again.
By "it" I mean the TPS.
[Re: jimbob101]
#1448568
06/07/13 06:55 PM
06/07/13 06:55 PM
Posts: 43,601 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Stopped for dinner at the Crackhead Barrel and unhooked the connector to the TPS three times. Just got back from the last 1,000 miles and the overdrive worked flawlessly! If only I would have checked here for the first 2,000 miles... My right foot was cramped-up good trying to get 65 MPH out of the truck with no OD.
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#1448569
06/07/13 09:03 PM
06/07/13 09:03 PM
pinkduster
Near Reading PA USA
Nice! 65 mph out of one of these trucks without OD is nuts! It must have been screamin'. Your nerves must be shot! I can't stand driving mine without OD. If it starts to act up, I pull over IMMEDIATELY and unplug it and plug it back in.
[Re: Rhinodart]
#1448573
06/08/13 02:01 AM
06/08/13 02:01 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
My 93 had the potentiometer conversion done.
I liked it, never had any trouble with it. I also liked having the ability to sdjust when the OD would engage.
If you do the swap, just remember a tiny adjustment on the know is all you need to move the OD engage speed. No need to do any real cranking of the dial.
Also as mentioned keep an eye on the VSS, and the plug in connector. These too will cause you to lose OD, but usually the speedo will either not register, or will bounce around if this is the problem.
My 93 went through 2 new VSS units in as many years.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
