66 Hemi Valve Cover Gasket
#1448416
06/06/13 01:27 PM
06/06/13 01:27 PM
Posts: 331 Northeast
edl
Northeast
had the car in for minor body work - while it was there i asked the guy to change the valve covers on a stock 426 ci hemi engine as oil was seeping out guys says he can't do it - something about "o-rings" - having never opened up the valve covers before or changed the gaskets, is there anything special? - anyone know what he is talking about? thx!
Re: 66 Hemi Valve Cover Gasket
[Re: JohnRR]
#1448420
06/06/13 01:58 PM
06/06/13 01:58 PM
edl
Northeast
thanks John - helps me get a visual snugging down the bolts is what they did - we'll see when it comes back if that took care of it if not, i'll remove the covers and change the gasket if i do change the gasket, should i change the o-rings? - are the o-rings removable from the tube or is it an integral piece such that the whole tube must be replaced? thx!
[Re: JohnRR]
#1448422
06/06/13 02:02 PM
06/06/13 02:02 PM
edl
Northeast
[Re: edl]
#1448423
06/06/13 02:12 PM
06/06/13 02:12 PM
edl
Northeast
[Re: JohnRR]
#1448427
06/06/13 02:33 PM
06/06/13 02:33 PM
edl
Northeast
[Re: JohnRR]
#1448430
06/07/13 02:19 AM
06/07/13 02:19 AM
Posts: 370 NASHVILLE
MAVERICKSHEMI
NASHVILLE
It looks like the o rings are on those ...
[Re: 52savoy]
#1448431
06/07/13 02:51 AM
06/07/13 02:51 AM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
one other thing... I don't think it was mentioned.
NEVER.. let someone work on your HEMI engine if they haven't had first hand experience.
Or ANY engine for that matter...
couple of things here...
make sure its actually the valve cover and not the block/head juncture..Very common to see oil leaks at the drainback holes(lower corners)..Many people are fooled by this thinking its the valve cover.
If you have to replace the gasket, get the one with the steel shim in between layers of gasket material..These will allow you to tigten the cover a bit more without distorting the gasket.
If you have the covers off and it has a solid cam in it, adjust the valves. Check the pushrods and make sure that they are getting properlly oiled.
As John said, prepare for a huge cloud of smoke when you restart the engine. I actually use the tube seals, even in stock builds. You'll never be able to properly read a plug unless you do. They intsall easy, just put them in the freezer beforehand to make them easier to dribe into the head.
Good Luck
MB
[Re: HPMike]
#1448433
06/07/13 09:25 AM
06/07/13 09:25 AM
Posts: 2,252 Sebring, Florida
Mopar Grandpa
Sebring, Florida
MB
I have a set of these gaskets if you need them. You can PM me for more info.
