Re: Door Adjustment help needed
[Re: 19SuperBee70]
#1448388
06/06/13 08:50 PM
06/06/13 08:50 PM
Posts: 162 nj
notforsale440
nj
check the screw holes that hold the latch in the door for fatigue cracks......make sure the screws are tight......adjust the door so it lines up nice without a striker, then install the striker to meet the door.........you may also have to shim the striker out to "reach" the latch properly
