1970 Duster heater blower motor question #1448371
06/06/13 08:59 AM
06/06/13 08:59 AM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
I'm in the process of rebuilding my heater box. The blower motor is in need of replacement. I've looked at replacement motors but the appearance is slightly "off" from the factory original.
I have a rear window defroster unit that I doubt I will put in the car. Could that motor be used for the heater since it is a factory motor in excellent condition? Are they the same or would there be differences?
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 1970 Duster heater blower motor question [Re: FJR doc] #1448372
06/06/13 09:46 AM
06/06/13 09:46 AM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
For beginners the shaft size is not the same.
Motor is shorter and less powerful.
Jules
Re: 1970 Duster heater blower motor question [Re: JulesdaWiperman] #1448373
06/06/13 11:14 AM
06/06/13 11:14 AM
Brownstown, PA
FJR doc Offline OP
FJR doc  Offline OP
Brownstown, PA
Thanks Jules. Any idea where I can locate a factory black motor for a non-ac car. I don't need date coding.
Kevin
Re: 1970 Duster heater blower motor question [Re: FJR doc] #1448374
06/07/13 10:11 AM
06/07/13 10:11 AM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
I have on for sale.....IM me
Re: 1970 Duster heater blower motor question [Re: JulesdaWiperman] #1448375
06/07/13 04:25 PM
06/07/13 04:25 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Jules
Are there any off the rack blower motors that fit even if not 100% correct appearing?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 1970 Duster heater blower motor question [Re: 71TA] #1448376
06/07/13 06:42 PM
06/07/13 06:42 PM
super gas
super gas
Sorry Jim I cannot answer that because I simply do not know.
Shaft size is very important and max.RPM speed also.
Jim while I have you here, can I send you a small gasket for headlight motors
and you can tell me if you can make some for me?
Tx
Jules
P.S. Maybe check with the Siemens catalog. They may have one.
Re: 1970 Duster heater blower motor question [Re: FJR doc] #1448377
06/07/13 07:04 PM
06/07/13 07:04 PM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
I'm in the process of rebuilding my heater box. The blower motor is in need of replacement...........
I just refinnished mine. '70 Dart Swinger.
If it just looks old, I wouldnt replace it.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: 1970 Duster heater blower motor question [Re: Copper Dart] #1448378
06/07/13 07:10 PM
06/07/13 07:10 PM
Copper Dart Offline
Copper Dart  Offline
sorry, wrong picture. I'll post the blower motor here in just a minute.
Mom.
Ricky Valdes
Re: 1970 Duster heater blower motor question [Re: Copper Dart] #1448379
06/07/13 07:19 PM
06/07/13 07:19 PM
Copper Dart Offline
Copper Dart  Offline
I couldnt find it so I took another. I hope this helps. I did it with rattle cans.
Mom.
Ricky Valdes
Re: 1970 Duster heater blower motor question [Re: Copper Dart] #1448380
06/07/13 08:07 PM
06/07/13 08:07 PM
super gas
super gas
Copper that is an a/c motor.
His is non a/c.
Jules
Re: 1970 Duster heater blower motor question [Re: JulesdaWiperman] #1448381
06/07/13 09:39 PM
06/07/13 09:39 PM
Stow ,Ohio
demon440 Offline
demon440  Offline
Stow ,Ohio
would one from a 71 Demon be the same?
I am not using mine.
Re: 1970 Duster heater blower motor question [Re: JulesdaWiperman] #1448382
06/08/13 09:15 AM
06/08/13 09:15 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Tx
Jules
I can do those. Shoot me one. Wit an end cap if you can so I can test fit.
Re: 1970 Duster heater blower motor question [Re: 71TA] #1448383
06/09/13 09:58 AM
06/09/13 09:58 AM
super gas
super gas
71 Demon is the same.
Jim, I will send you what you need.
Jules
