Heater Box Repair #144800
11/02/08 02:26 PM
11/02/08 02:26 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
What's a good product to use to repair/replace the usual broken areas on an E body heater box?
Grandma always said I had "hands of gold"!
Re: Heater Box Repair [Re: CHRGR69] #144801
11/02/08 02:29 PM
11/02/08 02:29 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Resto Rick (www.restorick.com) posted a very nice heater box repair process that he uses, you should check with him, VERY impressive work!
Re: Heater Box Repair [Re: ScottSmith_Harms] #144802
11/02/08 03:32 PM
11/02/08 03:32 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I bought the rebuilt kit from RestoRick and it came out awesome.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Heater Box Repair [Re: 70sixpkrt] #144803
11/02/08 03:36 PM
11/02/08 03:36 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Nice!! How much was the kit and what does it include?
Re: Heater Box Repair [Re: CHRGR69] #144804
11/02/08 07:06 PM
11/02/08 07:06 PM
70sixpkrt Offline
70sixpkrt  Offline
I think I spent about $40 for the kit that contains all the gaskets and foam for a rebuild.
4-speed
3:54 Dana
Re: Heater Box Repair [Re: CHRGR69] #144805
11/02/08 08:52 PM
11/02/08 08:52 PM
For the fiberglas housing, I use the stick marine epoxy. Works great.
Just form what you need and sand if to shape.
Re: Heater Box Repair #144806
11/02/08 08:55 PM
11/02/08 08:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
The housing is not fiberglass, it's a composite injection molded plastic part. You need to see what resto Rick did to repair his, I've never seen such a nice looking (and original appearing) repair. In fact the same repair could be used to fix an under hood air box for an air grabber car (same material as a heater box).
Re: Heater Box Repair [Re: ScottSmith_Harms] #144807
11/08/08 10:05 AM
11/08/08 10:05 AM
WI
RestoRick Offline
RestoRick  Offline
WI
