Re: Madd relay headlight wiring help
[Re: stateroadhog]
#1447955
06/05/13 06:09 PM
06/05/13 06:09 PM
Challenger 1
Cincinnati, Ohio
I did this last week and my head lights are much brighter, when my alternator was putting out above idle. Tonight I am installing a new alternator from powermaster after testing with another powermaster out of my other car. My old alternator never quit working, just not enough juice at near idle and not enough above idle. My car never went dead but it was not putting out like it should. My car runs much better with 14.5+ volts now too with factory electronic ignition.
[Re: stateroadhog]
#1447959
06/05/13 10:34 PM
06/05/13 10:34 PM
RapidRobert
The ammeter shows only how much current is flowing into the battery "shows positive on the ammeter" (charging) or out of the battery "showing negative on the ammeter" (discharging) not what is going on in the system as a whole which is OK as the batt state of charge is what is required to start it & is what is most important. Normally the headlights & everything else except for the starter is powered in the circuit after the ammeter (between ammeter & alt) & now your feeding the headlights from the circuit between the batt & the ammeter which is making the ammeter see the extra current going thru it to the relays on the batt side & it thinks the batt is taking current & being charged & in error it reads positive. Feeding the relays from the batt side still routes the current in/out of the bulkhead like OE (the problem area) sort of because the power for the relays has to come from the alt to the bulkhead/thru the underdash system/out the bulkhead to the relays on the batt side since even when the batt is topped off the relays (& everything else) are still fed from the alt output. I'd suggest feeding the relays from the alt (the source) which will keep headlight relayed current completely out of the bulkhead which is way better that it was OE & will keep your ammeter honest. If not I would run a 6 ga lead from the alt to the batt or starter relay possibly with a special fuse which this lead will render the ammeter inaccurate & add a voltmeter (a good idea anyhow) which this lead will help the vulnerable bulkhead. As said #1 slow charge the batt overnight on a charger
[Re: RapidRobert]
#1447960
06/06/13 12:17 AM
06/06/13 12:17 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Rapid Robert reported right. (There's your alliteration for today.) Putting the power for the relays on the starter relay stud (assuming '70 wiring is similar to '72, from FSM), will still cause power for headlight relay to be drawn through bulkhead connector. It avoids the headlight switch, so you've successfully eliminated THAT source of power weakness to headlights. However, power for the relays should come from the stud on the alternator, or at least a splice into the wire from the alternator (the large wire, not the field wires) before it goes into the bulkhead connector and into the dash harness splice. That's why the ammeter is reading high when headlights are on. The ammeter reads power toward the battery as a charge, it doesn't know that the load is the headlights. Best not to leave it this way - asking for trouble through ammeter, bulkhead connector, or elsewhere. If, or rather when, you do fix the source of power to headlight relay, make sure you put an inline fuse in the wire near where it begins to prevent future troubles if there's a short somewhere.
[Re: stateroadhog]
#1447962
06/06/13 07:58 AM
06/06/13 07:58 AM
Challenger 1
Cincinnati, Ohio
I was going to post that you should run a #10 wire last night but got sidetracked. The bad thing is it makes your amp meter useless. I drove mine like that since installing the #10 wire for years now. What I did pickup lately is a digital volt meter that plugs into the cig lighter to monitor my charging system. I wanted something simple and didn't want a separate volt meter under the dash somewhere. I keep mine in the console when not using it. That's how I noticed my old alternator was only doing about 13 volts with everything on at 2000rpms. The new alternator is charging up to 15 volts and I can feel it in the performance of the motor. The volt meter came from Camping world, 15 bucks or something like that being a good sam member. web page
[Re: Challenger 1]
#1447965
06/06/13 08:56 AM
06/06/13 08:56 AM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
Not really, it's just a cheap DVM. It's in my link above under "web page". It is a little slow on the readout like when the voltage changes but works.
I got one from Summit, very useful.
[Re: Ludington1]
#1447967
06/06/13 10:07 AM
06/06/13 10:07 AM
Posts: 4,748 Florida
BDW
Got a link?
Thx
