Which ATI damper to replace a fluiddamper? #1447558
06/04/13 03:03 PM
06/04/13 03:03 PM
North Sweden
RT540 Offline OP
RT540  Offline OP
North Sweden
I want the same meas. as the old fluid damper, will part nr 917470 fit the same. I have a custom made billet alum. pulley for both crank trigger and the dry sump HTD drive.
Re: Which ATI damper to replace a fluiddamper? [Re: RT540] #1447559
06/04/13 03:04 PM
06/04/13 03:04 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I think you are going to find that an ATI is thinner and you will need a spacer to make your pulleys line up.
2011 Drag Pak Challenger
Re: Which ATI damper to replace a fluiddamper? [Re: rickseeman] #1447560
06/04/13 03:26 PM
06/04/13 03:26 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Fact, just went through this on my 470 and had to space it a bit over 1/4" for my alt.
Re: Which ATI damper to replace a fluiddamper? [Re: Thumperdart] #1447561
06/04/13 03:40 PM
06/04/13 03:40 PM
North Sweden
RT540 Offline OP
RT540  Offline OP
North Sweden
Ok, thanks for the info.
I have a key slot for the pulley and the crank trigger wheel, so that will be easy.
Re: Which ATI damper to replace a fluiddamper? [Re: RT540] #1447562
06/04/13 03:53 PM
06/04/13 03:53 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I think that ATI offers several different spacings. You'll need to check.
Re: Which ATI damper to replace a fluiddamper? [Re: BSB67] #1447563
06/04/13 04:11 PM
06/04/13 04:11 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
yes they do,i got a thin one and my pullies lined up perfect.i dont know if i still have it but ill look and see,mabey i can get a # from it.
Re: Which ATI damper to replace a fluiddamper? [Re: bonefish] #1447564
06/04/13 04:16 PM
06/04/13 04:16 PM
North Sweden
RT540 Offline OP
RT540  Offline OP
North Sweden
Cool, that would be nice.
Just placed an order with Summit and the 7/16 dual taper push rods would be ordered in, so there´s probably a week before they get to ship the total package.
Tom
