oil filter delete? #1447444
06/04/13 01:12 PM
06/04/13 01:12 PM
missouri
W
werty Offline OP
werty  Offline OP
W
missouri
I am having a clearance problem with a set of Harold Johnsons Shorty headers on a 64 A-Body. I am thinking about deleting the oil filter as the car only runs about 150 miles each year at the drag strip. I am told that Offenhouser (not sure about spelling) used to sell a delete plate and plug for the side of the block. My worry is that I might be doing something goofy and cause an oil flow problem. I would appreciate any feed back especially from someone who's done this. I also plan to run a magnetic drain plug to collect metals. Thanks in advance.
Re: oil filter delete? [Re: werty] #1447445
06/04/13 01:16 PM
06/04/13 01:16 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I would look at a remote oil filter set up before I would delete it all together. I put 90* fittings and run lines to a filter on my Demon.
Re: oil filter delete? [Re: werty] #1447446
06/04/13 01:26 PM
06/04/13 01:26 PM
Aside from whether it is a good move or not to do it you'd want to plug all three ports (1 will already have a NPT plug) then from the oil sending unit hole in the top of the block drive the cup down & out of the #5 main bearing saddle after removeing the oil pump/#5 main cap. Now the oil will go straight up from the #5 cap then make a right turn into the pass (main) horizontle oiling gallery without being diverted sideways out to/from the filter.
Re: oil filter delete? [Re: RapidRobert] #1447447
06/04/13 05:16 PM
06/04/13 05:16 PM
scratchnfotraction Offline
when this is forgot it has a low oil psi if any psi at all.
so this is how it is done to delete the oil filtering.
dont see why it would be a problem.with that low of run time/milage often oil changes would be all thats needed.
no filters on 50s & 60s engines till the add on filters came along and then incorperated into the block itself.
no different from adding a 90* adaptor or a remote filter system.
the gallery plug is all the seperates it.
I would still thred/plug the oil passages on the outside of the block where the filter plate is missing.
Re: oil filter delete? [Re: scratchnfotraction] #1447448
06/04/13 06:03 PM
06/04/13 06:03 PM
UP
finn Offline
finn  Offline
UP
Remember that those old engines had babbit (soft)bearings which could accomodate debris in the oil and the engines had 7:1 compression ratios and ran at 3600-4000 rpm.
Bad Idea.
Re: oil filter delete? [Re: finn] #1447449
06/04/13 06:31 PM
06/04/13 06:31 PM
bc
3
37dodge Offline
37dodge  Offline
bc
this is my prototype for clearing the power rack. it looks like it will work.
Re: oil filter delete? [Re: scratchnfotraction] #1447450
06/05/13 09:17 AM
06/05/13 09:17 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
56 I believe almost all came with filters.Last car I worked on without a filter was a 55.Every one after that had a filter.Most were the cartridge type that sat in a canister.My 57 Chrysler was a real pain.I went to a spin on with adapter from Hot Heads.Rocky
Chrysler Firepower
