Basic rookie Q's - selection of tire/rims.
#1447379
06/04/13 09:54 AM
06/04/13 09:54 AM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Hey all, I'm looking to upgrade a stock '65 Satellite with better rims and tires. Not competition, not exotic, just a decent improvement over stock. Looking for some guidance or recommendations. I've always run stock rims on my Mopars. Never bought mags, etc. The extent of my tire experience is to head over to the tire shop I've used for decades, talk with the owner about the choices, pick a good set of radials and keep it balanced and aligned (my '67 Satellite currently has a set of GoodYear Assurance's on it and they are fine). Basic Facts: - The car is a freshly restored '65 Satellite factory big block. For a margin of improved handling I've equipped it with Firm Feel front and rear sway bars, Monroe Gas-Matic shocks on front, and Monroe Sensa-Traks on the rear. - The current rims are stock steelies 14" (x 5.5"?), 4.5" bolt pattern that are pretty well used, dented, etc. Time for new ones. - Tires that came with the car are General Tire 215/70R14 296's on stock steelie rims. Nothing refined about them. Time for new tires. What should a rookie like me be aware of in terms of basic dimensions before selecting a new set of slightly larger rims for a little more handling & road performance? I assume I keep the stock backspacing to avoid rubbing on the sway bars? My goals are: - Keep pretty much stock appearance. So I think I'd buy a new set of steel rims that I can keep the stock 14" push-on full hubcaps on (I recall a supplier who has an option on 15" steel rims that allow the stock 14" hubcaps). - Size the rims to accommodate a future upgrade to disc front brakes. Eventually rear discs are possible too. I see a lot of discs that fit behind 15" rims. - Don't want such a large size that I have to modify fenders or wheel wells to accommodate them. - I am attracted to Radir's Tri-rib style mags and might buy a set of them to change the look and "show category" of the car. Not sure whether I'd buy the same dimension as the steelies. Based on the wide use of 15x7 rims, I assume this is a size that is a good starting point for my needs that doesn't demand modifications elsewhere in the suspension, plus it has a lot of product selection. Is this true? Driving habits: - Personal, daily twisty country road pleasure driving. - Occasional long distance all day family highway trips. Thanks! -Art Here is the car:
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Basic rookie Q's - selection of tire/rims.
[Re: 67SATisfaction]
#1447381
06/04/13 10:43 AM
06/04/13 10:43 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
Nice car. I'd think a +1 concept would be best-ie the same overall dia with a wider/shorter tire. Size wise I come up with a 235/60-15. Tire Rack only shows 3 tires in that size. You could go to a 225/60-15, lose a little diameter but more options. HTH, Steve
[Re: jcc]
#1447383
06/04/13 07:58 PM
06/04/13 07:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Just be aware that varying the height from stock will affect the speedometer and odometer. There are ways to compensate if the variance is too much.
[Re: Supercuda]
#1447384
06/04/13 08:43 PM
06/04/13 08:43 PM
Posts: 1,008 wv
Dartcuda
wv
[Re: Dartcuda]
#1447385
06/05/13 09:58 PM
06/05/13 09:58 PM
Posts: 20,754 A collage of whims
topside
A collage of whims
There are some "period-correct" options if that's what you want - Cragar S/S, American Torque-Thrust come to mind; and I've seen chrome Magnum 500s on those cars that looked nice, though it's a bit later wheel. Given the colors on your car, I'd likely prefer a chrome or polished wheel, but your opinion may differ. When I wanted to run 14" wheels on a Road Runner, I bought 14x7s and they helped the cornering a bit compared to the 5.5 width; I ran 225/70 or 235/70 tires. A larger wheel, say 15x7, and a 60-series tire, will step up the cornering, and a 235 front and maybe 275 rear are about as big as you can fit. You can also get a 15x8 rear wheel in there with 4.5 backspace. I think Firestone's Indy 500 series is still the best bang-for-buck street tire, but that may have changed.
[Re: topside]
#1447386
06/05/13 11:31 PM
06/05/13 11:31 PM
67SATisfaction
Albany, NY
Thank you all for the input, guys. I appreciate it. I'll take a day or two to digest the options and narrow down some of your collective ideas. Thanks especially for the tire size input. The Radir's would be a future upgrade, for now my desire is to stick with steelies. The Radir Tri-Rib is actually very close to period correct, I got the idea from a period photo posted here of some USAF Officers in a brand new '65 Sat with similar mags. It looked sharp. And there are some guys running Radir's on their '63 and '64 Dodge drag cars at Lebanon Valley, so I even have personal exposure to them - they looked great, yes polished but not chromed. Hi JC! Is this what you're asking about... ?
[Re: ThermoQuad]
#1447390
06/11/13 11:27 PM
06/11/13 11:27 PM
67SATisfaction
Albany, NY
Back on topic - Quote:
15x7 wheel 235 60 15 tire which translates to 26.1 inches tall & 8 inches of tread. This is what will work best on your car and you will not be disappointed
Thanks Tom, I appreciate the direct recommendation. I talked briefly with the tire shop. We agreed I'll bring the car over there and have a look at their offerings. I'll roll a sample tire or two outside to the car so I can see the size and how it looks, before I pull the trigger
-Art
