B & M externally balanced flex plate for 73 340? #1447088
06/03/13 09:01 PM
06/03/13 09:01 PM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
Hey there, was going to buy the B&m flex plate part #10235 for 340 cast crank external balance but lists for 340/727 and I am using the 904. It does have dual pattern torque converter in 10 inch and 11.125 inch, part #10234 is for the 340/904 but is no longer available. My question would be is the dual pattern so you can use a 904 or 727? Of course the B&M tech line has no idea.
Re: B & M externally balanced flex plate for 73 340? [Re: gtsdude] #1447089
06/03/13 10:09 PM
06/03/13 10:09 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Simple answer...
If the bolt pattern matches your converter and no issues with starter clearance (grind a little on starter if necessary) it works.
Only difference is the overall diameter from the 904 and 727 listings.
Re: B & M externally balanced flex plate for 73 340? [Re: RobX4406] #1447090
06/03/13 10:27 PM
06/03/13 10:27 PM
S.E. Minnesota
gtsdude Offline OP
gtsdude  Offline OP
S.E. Minnesota
Thanks, I can deal with a little grinding on the starter if need be.
Re: B & M externally balanced flex plate for 73 340? [Re: gtsdude] #1447091
06/04/13 02:57 PM
06/04/13 02:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some people have reported starter interference with the outer rim of the flexplate when using the 727 flexplate on a 904.
