Tubbed Out 72 Charger #1447051
06/03/13 08:26 PM
06/03/13 08:26 PM
Canada
Flatblack Offline OP
Canada
Has anyone Tubbed out a 71 and up B Body? I would like to be able to put wider tires on but still would like a back seat, any ideas are sure to b appreciated!
Thankx, just a student trying to save a buck! flatblack68@gmail.com
Re: Tubbed Out 72 Charger [Re: Flatblack] #1447052
06/03/13 08:35 PM
06/03/13 08:35 PM
FL
74-440Charger Offline
FL
Re: Tubbed Out 72 Charger [Re: 74-440Charger] #1447053
06/04/13 12:06 AM
06/04/13 12:06 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Unless you relocate the leaf springs your not going to gain anything by tubing it..
I am truckless..
Re: Tubbed Out 72 Charger [Re: 340SHORTY] #1447054
06/04/13 02:29 AM
06/04/13 02:29 AM
Canada
Canada
so if I relocate the leaf springs to the original chasis structure and reinforce it should work right?
Re: Tubbed Out 72 Charger [Re: Flatblack] #1447055
06/04/13 02:46 AM
06/04/13 02:46 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
How wide of tire are you wanting to go? The 71-74 B bodies already have a lot of room back there, especially if you relocate the leaf springs.
Re: Tubbed Out 72 Charger [Re: DaytonaTurbo] #1447056
06/04/13 02:55 AM
06/04/13 02:55 AM
Canada
Canada
nothing to crazy but wide enough so I can get better traction and not have the tread sticking outside of the body,
Re: Tubbed Out 72 Charger [Re: Flatblack] #1447057
06/04/13 06:49 AM
06/04/13 06:49 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
what are you running for a rear tire now ?
I am truckless..
Re: Tubbed Out 72 Charger [Re: 340SHORTY] #1447058
06/04/13 07:23 AM
06/04/13 07:23 AM
Canada
Canada
i would like to ride a set of 15x10' rims I got given to me from a friend??
Re: Tubbed Out 72 Charger [Re: Flatblack] #1447059
06/04/13 07:33 AM
06/04/13 07:33 AM
michigan woods
imfixinmopars426 Offline
michigan woods
consider mini-tubbing,and install a inboard spring mount in the frame,and that will be plenty of room.someone else here that has a done car should chime in to give exact measurements,but I would guess 12-14" width would be easy...just remember,big tires are very expensive,so add up costs before you cut,lol....mike...oh,i have 15x8+295-65-15's on mu 72 charger w/ no mods.
Re: Tubbed Out 72 Charger [Re: Flatblack] #1447060
06/04/13 08:45 AM
06/04/13 08:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You can get a 11" maybe a 12" tire under that car w/o anykind of tubbing or spring relocation. How much power are you throwing down? It might be money better spent looking at upgrading your rear springs, and shock combo.
Coming soon!!!!
Re: Tubbed Out 72 Charger [Re: Mr.Yuck] #1447061
06/04/13 02:45 PM
06/04/13 02:45 PM
Manitoba, Canada
Manitoba, Canada
I did some measuring on mine and I can fit a 325/50/15 under the car with only a spring relocation. That would need a 10" rim with a custom backspacing and that tire measures 13.25" wide from bulge to bulge. I assume chargers have about the same space back there are their plymouth counterparts.
Re: Tubbed Out 72 Charger [Re: Flatblack] #1447062
06/04/13 11:31 PM
06/04/13 11:31 PM
FL
FL
I run a 28X10.50 ET Drag slick on 10" wide 15" rims with 5" of backspacing with no modifications.
Re: Tubbed Out 72 Charger [Re: 74-440Charger] #1447063
06/05/13 04:04 PM
06/05/13 04:04 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I am running 15 x 10 with a 5 inch backspace and 295/65/15 on my 74. I went with the offset shackles as stated above. You will have to weld new perches to the rear end housing and the rest is a bolt in deal.
Re: Tubbed Out 72 Charger [Re: Flatblack] #1447064
06/05/13 07:33 PM
06/05/13 07:33 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I run 18x10 which makes for 12" of tire.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Tubbed Out 72 Charger [Re: dfsmopars] #1447065
06/05/13 07:40 PM
06/05/13 07:40 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
15x12 on mine with a 30/12.5 ET Street on mine with a mini-tub, I have tons of room.
Photobucket sucks
Re: Tubbed Out 72 Charger [Re: 72chrgrally] #1447066
06/07/13 06:52 PM
06/07/13 06:52 PM
Canada
Canada
thanks for the replies.
Maybe I will have to take a better look at relocating the springs, I would like to do maybe a mini Tub but then i'd have to mess with the trunk mechanism and that looks complicated?!
So if I relocate the springs I would probably have to customize the rear end to fit?
