Dave, I'd think you could spot weld the rivet to the arm where it's loose. I've also heard of degreasing the area and letting some epoxy ooze into the gaps to tighten the fit of the rivet*.
*you mean the rivet is loose where it's supposed to be fixed to the intersecting arm?
Or - If the rivet's spindle is a bit worn so the two arms are loose relative to each other, I'd just grease it and leave it.
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
