340 Cam Question
#1446624
06/03/13 02:44 AM
06/03/13 02:44 AM
Posts: 161 Logansport, Indiana
Budman
Logansport, Indiana
I just bought a 69 340. I have some #'s off of the front of the Cam but cant find what it is. Need Help!! This is on the Cam CD 16003 5-4 800-801
Also, when going back together I want to double check something. The Hollow Bolt in the Cam Thrust Plate goes in top passenger hole? Correct?
All MOPARS & nothig else.
Re: 340 Cam Question
[Re: Budman]
#1446625
06/03/13 09:24 AM
06/03/13 09:24 AM
Posts: 15,487 Florida
scratchnfotraction
correct on the thrust plate oil thru bolt
no help on cam ID.
[Re: Budman]
#1446630
06/05/13 09:23 AM
06/05/13 09:23 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Do all 340's have the hollow thrust plate bolt? Not saying my '71 model 340 doesn't have it, I just didn't notice it. Might have to pull the timing cover back off and check.
[Re: an8sec70cuda]
#1446631
06/05/13 10:33 AM
06/05/13 10:33 AM
Posts: 52,972 Romeo MI
MR_P_BODY
All the small blocks had the hollow bolt.. doesnt mean you have to have it but with the chain it does drip oil on it to lube it better
[Re: MR_P_BODY]
#1446632
06/05/13 11:19 AM
06/05/13 11:19 AM
scratchnfotraction
not all SB came with the oil thru bolt,it was replaced with the metal drip tab that goes on the lower bolt and hooks in the unused lower hole in thrust plate.
