Metalic oil ??? #144634
11/02/08 11:14 AM
11/02/08 11:14 AM
Kansas
racincuda Offline OP
Kansas
Well i hav seen so many post here about flat cams that I felt complelled or maybe driven to ad this one. Thought sure I would dodge this pitfall cuz the cam was prevoiusly run in however I had to change lifters cuz they got rusty waiting on me to reassemble the engine. Now that it runs my rockers go out of adjustment quickly, intakes loose and exhaust too tight The oil always looks clean untill I poke a finger into one of those low spots that always hold oil, now I see metalic flakes Bummer
Sooo now the billion dollar question is ther any way short of a complete rebuild to save this mess
Really wasnt lookin forward to going bac to the machine shop a layin out another 2 thou for a second rebuild.
Re: Metalic oil ??? [Re: racincuda] #144635
11/02/08 11:23 AM
11/02/08 11:23 AM
doesn't sound good. What eng?
Re: Metalic oil ??? [Re: RapidRobert] #144636
11/02/08 11:45 AM
11/02/08 11:45 AM
Kansas
Kansas
340 13:1 W2 solid flat tappet crower cam
Re: Metalic oil ??? [Re: racincuda] #144637
11/02/08 11:51 AM
11/02/08 11:51 AM
You tossed the rusted lifters when you finally ended up going together
Re: Metalic oil ??? [Re: RapidRobert] #144638
11/02/08 11:59 AM
11/02/08 11:59 AM
Kansas
Kansas
Yea hated to do that cuz they were lite weight race lifters, cam was fine. Should have had lifters submerged in oil. Live n learn I guess
Re: Metalic oil ??? [Re: racincuda] #144639
11/02/08 12:11 PM
11/02/08 12:11 PM
I've done it. I'd like to have a heated garage so that condensation wouldn't be an issue every winter. All I need is a winning lottery ticket or marry a wealthy woman or come up with a better idea on how to cook fried chicken than the colonel has or even better stop procrastinating on my projects . No idea yet where the flakes are coming from? or why the rockers won't hold an adjustment. If you corrected the issue you could dissassemble & clean everything up & go back together & maybe not have a horrendous bill.
Re: Metalic oil ??? [Re: RapidRobert] #144640
11/02/08 12:24 PM
11/02/08 12:24 PM
Oh so you didn't go thru the breakin procedure when you changed the lifters
Re: Metalic oil ??? [Re: racincuda] #144641
11/02/08 03:07 PM
11/02/08 03:07 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
When I wiped out the cam on my 360, the metal particles got to the bearings and oil pump
Anyhow, I ended up with just re-hone the cylinders, and new rings, bearings, gaskets, and the new cam and lifters.
Re: Metalic oil ??? [Re: RapidRobert] #144642
11/02/08 03:09 PM
11/02/08 03:09 PM
Kansas
Kansas
yea I kept th revs up for at least th first 30 minutes but Im not really tryin to figure out what happened as much as Im hoping to find a way around a complete rebuild
Next time I will drive it like I stole it !
It will either Go or BLOW
Re: Metalic oil ??? [Re: racincuda] #144643
11/02/08 04:40 PM
11/02/08 04:40 PM
Kansas
Kansas
451 mopar that sounds like a rebuild to me, but you didnt hav to buy new pistons ?
that would be some good news
Re: Metalic oil ??? [Re: racincuda] #144644
11/02/08 09:37 PM
11/02/08 09:37 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Before you get crazy, check your valve spring shims. If the stuff is aluminum flakes, good chance its the shims, unless they are the good correct hardened cups/shims. Both my heads do this , makes me want to kick the machineists in the nuts.
Re: Metalic oil ??? [Re: RemCharger] #144645
11/02/08 09:50 PM
11/02/08 09:50 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I made the same mistake. I put an old cam with new lifters and wiped out two lobes. Take her apart and clean it up. Gaskets, rings, bearings and the works. You should not need new pistons. Just get all the metal out of the shirts if it has any embedded it them.
Re: Metalic oil ??? [Re: racincuda] #144646
11/03/08 09:01 AM
11/03/08 09:01 AM
pittsburgh,Pa.
mikepar Offline
mikepar  Offline
pittsburgh,Pa.
cam and lifters should always always always be replaced together
Re: Metalic oil ??? [Re: mikepar] #144647
11/03/08 09:19 AM
11/03/08 09:19 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
i got some bad lifters in my kit from Comp. the pistions in side the lifter bodys are two tight. i have taken four apart and honed them trying to save the lifter boby because it's broke in to the cam. i still have one ticking. i think i am going to take it back out and work it again. i called Comp. they said take out the cam and lifters and send them to them if that was the problem they would replace them. thats great except i don't want to take it apart again. i ask about putting new lifters in and they said 50% chance that they would break in. there is a clear differance in the lifters they are using now and a year ago. i feel like if i wanted a 100.00 cam and lifters i would have bought a cheap kit. but the new Comp lifters looks like the cheap lifters.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: Metalic oil ??? [Re: 65cuda] #144648
11/03/08 09:33 AM
11/03/08 09:33 AM
Kansas
Kansas
Remcharger does th aluminum flakes cause the same problems as wiped lobes ?
I really think the cam is gone cuz the lash adjusment loosens up quickly on intakes exhausts seem to git tighter
I will lookin at the lifters soon, that tell most of the rest story.
Re: Metalic oil ??? [Re: racincuda] #144649
11/03/08 10:52 AM
11/03/08 10:52 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
lobes go fast. once it goes through the surface hardening then its soft metal. if you don't have a dail indcator to check the lift. have some one crank it while you watch the rockers. it's easy to see if a lobe is gone compared to one next to it.
Re: Metalic oil ??? [Re: 65cuda] #144650
11/03/08 03:40 PM
11/03/08 03:40 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Cut open the oil filter with a pair of tin-snips. If the shavings are on the motor, you'll find them in there.
