Metalic oil ???
#144634
11/02/08 11:14 AM
11/02/08 11:14 AM
Posts: 650 Kansas
racincuda
Kansas
Re: Metalic oil ???
[Re: racincuda]
#144637
11/02/08 11:51 AM
11/02/08 11:51 AM
RapidRobert
You tossed the rusted lifters when you finally ended up going together
Re: Metalic oil ???
[Re: racincuda]
#144639
11/02/08 12:11 PM
11/02/08 12:11 PM
RapidRobert
I've done it. I'd like to have a heated garage so that condensation wouldn't be an issue every winter. All I need is a winning lottery ticket or marry a wealthy woman or come up with a better idea on how to cook fried chicken than the colonel has or even better stop procrastinating on my projects . No idea yet where the flakes are coming from? or why the rockers won't hold an adjustment. If you corrected the issue you could dissassemble & clean everything up & go back together & maybe not have a horrendous bill.
Re: Metalic oil ???
[Re: RapidRobert]
#144640
11/02/08 12:24 PM
11/02/08 12:24 PM
RapidRobert
Oh so you didn't go thru the breakin procedure when you changed the lifters
Re: Metalic oil ???
[Re: racincuda]
#144641
11/02/08 03:07 PM
11/02/08 03:07 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
When I wiped out the cam on my 360, the metal particles got to the bearings and oil pump Anyhow, I ended up with just re-hone the cylinders, and new rings, bearings, gaskets, and the new cam and lifters.
Re: Metalic oil ???
[Re: mikepar]
#144647
11/03/08 09:19 AM
11/03/08 09:19 AM
Posts: 515 Dayton, Ohio
65cuda
mopar addict
mopar addict
Dayton, Ohio
i got some bad lifters in my kit from Comp. the pistions in side the lifter bodys are two tight. i have taken four apart and honed them trying to save the lifter boby because it's broke in to the cam. i still have one ticking. i think i am going to take it back out and work it again. i called Comp. they said take out the cam and lifters and send them to them if that was the problem they would replace them. thats great except i don't want to take it apart again. i ask about putting new lifters in and they said 50% chance that they would break in. there is a clear differance in the lifters they are using now and a year ago. i feel like if i wanted a 100.00 cam and lifters i would have bought a cheap kit. but the new Comp lifters looks like the cheap lifters.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
Re: Metalic oil ???
[Re: racincuda]
#144649
11/03/08 10:52 AM
11/03/08 10:52 AM
65cuda
mopar addict
mopar addict
Dayton, Ohio
lobes go fast. once it goes through the surface hardening then its soft metal. if you don't have a dail indcator to check the lift. have some one crank it while you watch the rockers. it's easy to see if a lobe is gone compared to one next to it.
Re: Metalic oil ???
[Re: 65cuda]
#144650
11/03/08 03:40 PM
11/03/08 03:40 PM
Posts: 4,449 Michigan
MarkZ
Worthy
Worthy
Cut open the oil filter with a pair of tin-snips. If the shavings are on the motor, you'll find them in there.
