correct 69 b body trunk seal? #1446490
06/02/13 09:05 PM
06/02/13 09:05 PM
indy
70moparmike Offline OP
indy
if you look in the metro soft seal book they had a different profile, smooth. look in the restoration specialties and supply book and it is a molding that has a split molded into the seal that is like a double edge? witch is the correct seal for the trunk?? i am sure most have run into this and should not be to hard of a question for an answer. thanks moparts
Re: correct 69 b body trunk seal? [Re: 70moparmike] #1446491
06/02/13 10:06 PM
06/02/13 10:06 PM
indy
indy
Re: correct 69 b body trunk seal? [Re: 70moparmike] #1446492
06/02/13 10:54 PM
06/02/13 10:54 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline
44D6PAKCUDA  Offline
This is always one subject that nobody ever seems to know for sure what the correct answer is.One person will say the design of the original trunk seal is the same from car to car(A Body to E Body,etc)and that only the legnth is different and the next guy will say each trunk weatherstrip is unique design to each body style.Maybe someone will come thru this time with good info.
Re: correct 69 b body trunk seal? [Re: 44D6PAKCUDA] #1446493
06/03/13 08:09 AM
06/03/13 08:09 AM
indy
indy
anybody else on an opinion??
Re: correct 69 b body trunk seal? [Re: 70moparmike] #1446494
06/03/13 08:29 AM
06/03/13 08:29 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I hear trunk seal with part numbers molded into them are in the works.
Re: correct 69 b body trunk seal? [Re: autoxcuda] #1446495
06/03/13 09:39 AM
06/03/13 09:39 AM
indy
indy
any idea what is correct between the two designs?
Re: correct 69 b body trunk seal? [Re: 70moparmike] #1446496
06/03/13 09:25 PM
06/03/13 09:25 PM
Ill try and take a pic of the original one that is on our 69 GTX vert tomorrow.
Re: correct 69 b body trunk seal? [Re: ] #1446497
06/04/13 08:04 AM
06/04/13 08:04 AM
indy
indy
thanks, would appreciate that.
Re: correct 69 b body trunk seal? [Re: 70moparmike] #1446498
06/04/13 10:54 AM
06/04/13 10:54 AM
Minnesota
3twos Offline
3twos  Offline
Minnesota
Al & Sheila
Re: correct 69 b body trunk seal? [Re: 3twos] #1446499
06/04/13 12:53 PM
06/04/13 12:53 PM
indy
indy
thanks, it kinda looks like the split design?
Re: correct 69 b body trunk seal? [Re: 70moparmike] #1446500
06/04/13 11:29 PM
06/04/13 11:29 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
From my 69' roadrunner (original)
Hope it helps
Re: correct 69 b body trunk seal? [Re: pacifica] #1446501
06/04/13 11:30 PM
06/04/13 11:30 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Re: correct 69 b body trunk seal? [Re: pacifica] #1446502
06/05/13 10:05 AM
06/05/13 10:05 AM
indy
indy
so the originals are the split design, wonder why the largest supplier is selling the wrong design to everyone???
Re: correct 69 b body trunk seal? [Re: 70moparmike] #1446503
06/05/13 11:42 AM
06/05/13 11:42 AM
west australia
8trackbee Offline
8trackbee  Offline
west australia
don't get me started, what they could do in 69 they can't do in 2013... i'm in Australia and will need one for the Bee, hope you find one, and let us know.....
