Retorquing head bolts after initial fire up: myth? #1446227
06/02/13 11:24 AM
06/02/13 11:24 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Hi!
I hear there are a lot of guys that retorqye head bolts and manifold bolts after having fired up the engine for the first time and used driven it around some...
Is it adviseable or is it not needed? truth or myth?
Im asking because I dont see production line engines needing that....
Re: Retorquing head bolts after initial fire up: myth? [Re: domingo] #1446228
06/02/13 11:37 AM
06/02/13 11:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never re-torqued the heads... I do the 3 step
torque process and call it good.... but maybe thats why
I dont ever make any big power... but the head gaskets
never show any leak
EDIT
I do check them the next morning if I didnt finish
up the top end... but never seen it change
Re: Retorquing head bolts after initial fire up: myth? [Re: domingo] #1446229
06/02/13 11:37 AM
06/02/13 11:37 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I personally don`t and go 5-7 years average on my rebuilds mostly street w/a few scattered passes here and there.......
Re: Retorquing head bolts after initial fire up: myth? [Re: Thumperdart] #1446230
06/02/13 12:08 PM
06/02/13 12:08 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have never ever retorqued a head gasket in my life. But then again I spray every head gasket I put on with High-tac sealer.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Retorquing head bolts after initial fire up: myth? [Re: pittsburghracer] #1446231
06/02/13 09:29 PM
06/02/13 09:29 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I run Cometics sprayed with Permatex spray copper and have never had an issue of not re-torquing,,,come to think of it I have never had issues with Fel-pro perma torques eather.
Re: Retorquing head bolts after initial fire up: myth? [Re: domingo] #1446232
06/02/13 11:15 PM
06/02/13 11:15 PM
The only ones I have retorque where copper on a all aluminum Hemi motor with a big blower, 1000HP +. I did it to ease my consciuos to make sure I had done everything possible to insure that all bases where covered. Never on any other motors, even with copper head gaskest mixed with iron block and aluminum heads Your call
Re: Retorquing head bolts after initial fire up: myth? [Re: domingo] #1446233
06/03/13 06:00 AM
06/03/13 06:00 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I retorqued the headbolts on a generic 327 SBC motor way back in the day. Don't think I actually made it through the whole set. It was pretty obvious that the elasticaty/stretch of the headbolts were holding torque very well
Aluminum heads tend to expand more and may need it. I'll check that once I put mine together.
I always recheck intake manifold bolts periodically since I have found them to be loosened up on many used vehicles I've bought. They have a lower torque value to begin with.
Re: Retorquing head bolts after initial fire up: myth? [Re: domingo] #1446234
06/03/13 09:57 AM
06/03/13 09:57 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I've never done it.. I just follow the shop manual sequence and have never had an isue with steel shim or Fel=Pros.
Coming soon!!!!
Re: Retorquing head bolts after initial fire up: myth? [Re: Mr.Yuck] #1446235
06/03/13 02:20 PM
06/03/13 02:20 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Never used to do it on all iron motors.
We had issues with the fire rings distorting and burnishing the head on the 572 motor, we now re-torque the heads and we don't have the problem.
They do seem to loosen off after the initial fire up and cool down. All alloy motor.
EDIT: Fel-Pro instructions tell you to re-torque for racing applications BTW
Re: Retorquing head bolts after initial fire up: myth? [Re: Tig] #1446236
06/03/13 03:22 PM
06/03/13 03:22 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I usually do a re-torque after engine has been brought up to operating temp, then coolant drained, and allowed to cool overnight. This is on an engine that I have had on the test stand and have the time to do it. If I do work where the motor is not ran here, I do not go find it and re-torque.
If you like drag racing, support your local track.
Re: Retorquing head bolts after initial fire up: myth? [Re: domingo] #1446237
06/03/13 06:10 PM
06/03/13 06:10 PM
Delray beach, Florida
P
Performance Only Offline
P
Here you go. Pay particular attention to paragraph 9 and the paragraph after that.
machine shop owner and engine builder
Re: Retorquing head bolts after initial fire up: myth? [Re: Performance Only] #1446238
06/03/13 08:59 PM
06/03/13 08:59 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Dan,
The cold re torque method doesnt say this is done after haven broken in the engine, but 1 hour after the initial torquing of the head to the block? So this is part of the assembly process even before firing it up fot the first time?
I guess what CHAPPER is saying is that he does the same procedure of retorquing the bolts, but he also backs up them some before retorquing (thats why he says he drains the engine of all fluids first) and then torques again to spec? Hey Chapper, did I get it right?
I am asking because when I have seen people doing the retorque, they go and just set their torqmeters to the desired rating, and then they just torque them without draining fluids and loosening the head bolts some....which I would think is wrong since maybe the torque reading might only (or partly) be from just twisting the bolt heads, instead of further stretching the fasteners to the deisred spec.
Re: Retorquing head bolts after initial fire up: myth? [Re: domingo] #1446239
06/04/13 01:34 AM
06/04/13 01:34 AM
louisiana
hemi-hunter Offline
hemi-hunter  Offline
louisiana
I run an o-ring hemi block with copper head gaskets and I retorque after I run the engine for 15 minutes after intial start up. of course I wait until the engine cools down to 100 degrees before torqueing.
Re: Retorquing head bolts after initial fire up: myth? [Re: domingo] #1446240
06/04/13 03:17 AM
06/04/13 03:17 AM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Dan,
I use the 3 step version on Cometic on my engines and wait for about 20 min and then i loosen and retorque one bolt at a time in cross pattern ! Works good on a 11,5:1 RB stroker whit no issues
