Where to buy? #1445997
06/01/13 10:20 AM
06/01/13 10:20 AM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
Does anyone know where I can buy the oil plug that is installed in the oil passage beneath the main cap? I installed a 19/32 freeze plug, but it was slightly larger than the original (and quite hard to get to go in...). I'm worried that it's not pushed down far enough, and would prefer to install the correct part.
'64 390 Valiant Signet Convertable (WIP...)
Re: Where to buy? [Re: capac] #1445998
06/01/13 10:50 AM
06/01/13 10:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Go back to your local parts store with calipers in
hand and start measuring the plugs... they are not
all made equal... find one with a .002 to .0025 press fit
what is the press fit on what you have now
Re: Where to buy? [Re: capac] #1445999
06/01/13 10:56 AM
06/01/13 10:56 AM
Az
Crizila Offline
Crizila  Offline
Az
The Mopar part # is PN 3462871. Probably get one from Mancini. It needs to be pressed down 2 1/4" measured from the plug to the cap mating surface. Actually, the book gives you a install range of 2 1/8" to 2 5/16" from the bottom of the block.
Fastest 300
Re: Where to buy? [Re: MR_P_BODY] #1446000
06/01/13 12:13 PM
06/01/13 12:13 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
I'm not quite sure how I would measure the opening where the plug sits (it is narrower than the opening where the main cap sits). Having said that, I measured the original plug and it is .565. The plug that I tried putting in is .593. Also, the furthest I could get it down was 1.831 inches. I'll see if I can't find a plug closer to the .565 size, so I can get it down far enough.
Re: Where to buy? [Re: Crizila] #1446001
06/01/13 12:18 PM
06/01/13 12:18 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
I measured the depth of the original plug before removal and it was sitting right around 2.125. I sourced that part # on Dorman's website and it says that it is a .563 plug. Strange that the new one would be .002 smaller than the used one. I assumed that the plugs would get smaller from being installed.
Re: Where to buy? [Re: capac] #1446002
06/01/13 03:04 PM
06/01/13 03:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would go and measure this one to see what it really is...
but you would never get the .595 one to fit
Re: Where to buy? [Re: MR_P_BODY] #1446003
06/01/13 04:04 PM
06/01/13 04:04 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
Napa had one that measured .569 and it fit perfectly. Makes me wonder if the .563 one mentioned earlier would even work. Thanks for the help guys!
