I'll keep an eye out around here. At pull-apart I think they are around $25 or $30.
Remember that from 73 up until 7??? the B bodies used the same arms. Charger, Satellite, Cordoba, I think even some Diplomats & later Newports or maybe it was the Fury that also used the B body Chasis. If it looks the same it will fit. The Mirada's used a transverse T-bars and are different. You can see where the T-bar mounts on the LCA instead of having the HEX in the back of the bushing. It doesn't have to be a 73/74 B body.
Put an add in the wanted section here lots of people here are very helpful.
Good Luck
