A12 fender tag help #1445724
05/31/13 06:53 PM
05/31/13 06:53 PM
Back In Iowa
belv2vert66 Offline OP
Back In Iowa
Helping a friend out with this. I can tell the car is coded for a vinyl top by the 1X.
We believe it to be black vinyl top.
The broadcast sheet is available but I don't have a good pic of it.
2 Questions:
1)if you were restoring this car to the tag. What would you put on the top ? or do I need to see the broadcast sheet ?
2) What does the 7X signify on the same line as the 1X ?
Thanks All ! I am sure I will have more questions when I get the picture of the broadcast sheet
Re: A12 fender tag help [Re: belv2vert66] #1445725
05/31/13 07:05 PM
05/31/13 07:05 PM
new york
badsixpack Offline
badsixpack  Offline
new york
i think it means black top and black stripe down the side of the car but not sure.. some one will chime in who does
Re: A12 fender tag help [Re: badsixpack] #1445726
05/31/13 07:28 PM
05/31/13 07:28 PM
Buffalo, NY U.S.A.
MrNormsTA Offline
MrNormsTA  Offline
Buffalo, NY U.S.A.
1X black vinyl top.
7X painted accent stripe down the side.
Here is a good post on the 7X.
https://board.moparts.org/ubbthreads/showflat.php?Number=7427665
Rick.
