The 383 in my Fury conv overheats as sson as I drive the car at more than 60 mph. If the car is standing, it doesn't seem to overheat. I have checked the water/ antifreeze, and it's very dirt. I tried to wash cooling system with a garden hose, but no luck. Car has about 40.000 miles, has been standing in the open for many years and has Always had this problem. I left in storage for a couple of years, and now problem has gotten worse. Radiator is new, 3 row 26 inches, new Thermal fa, shroud and 7 blade fan. Advance is correct. No water in the oil. I am pretty sure the engine is clogged with rust and mud in the water passages, as water is rusty and dirty. How do I clean the water passages without hot tanking the engine? I was thinking about removing freeze plugs on the sides of the block. Any other idea?
Thank you
