heater core removal under the dash #1445463
05/31/13 08:53 AM
05/31/13 08:53 AM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
I am getting a coolant leak inside the car from under the dash whenever I nail the throttle after running 5-10 minutes. - I am assuming it is right at the hose connection. I am not sure if this is a pressure thing or a airlock situation.
What I would like to know is can I drop the heater box from under the dash without removing the dash itself. I had restored the core box and did a pressure test of the heater core itself. The removal and install was done during a car strip down stage so nothing was in the way. Now I am assembled.
thanks
Re: heater core removal under the dash [Re: 454Baja] #1445464
05/31/13 08:58 AM
05/31/13 08:58 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
What car?
And I doubt that it is a connection leak? and not a air lock issue.
More than likely it's a rotted out heater core. Always replace them when you have the box open. They don't last forever.
Re: heater core removal under the dash [Re: Challenger 1] #1445465
05/31/13 09:03 AM
05/31/13 09:03 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I agree, doubt it is connection. And even a newer core could be leaking if it is Chinese junk. I haven't accessed a lot of them but the ones I have on my M and F body Mopars require pulling the dash.
Facts are stubborn things.
Re: heater core removal under the dash [Re: larrymopar360] #1445466
05/31/13 10:06 AM
05/31/13 10:06 AM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
Sorry
It is a 70 roadrunner
As mentioned I did pressure test it and did not see any signs of rot, I believe it was original and not import. Anyways that is why I was thinking connection but if the dash has to be pulled I will bypass for now and what till the snow flies.
thanks
Re: heater core removal under the dash [Re: 454Baja] #1445467
05/31/13 10:57 PM
05/31/13 10:57 PM
Upstate NY
454Baja Offline OP
454Baja  Offline OP
Upstate NY
does anyone know what I need to remove to get to this heater core?
remove windshield & dash?
remove the core box from under the dash?
remove just the heater core from the box? How
thanks again
Re: heater core removal under the dash [Re: 454Baja] #1445468
05/31/13 10:59 PM
05/31/13 10:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Can't help on a B body, but my Dart and my Diplomat did NOT require pulling the dash to drop the heater box. Might be wise to invest in a factory service manual as it will detail this chore nicely.
Don't be the exception.
Re: heater core removal under the dash [Re: Supercuda] #1445469
05/31/13 11:57 PM
05/31/13 11:57 PM
IN
ahy Offline
ahy  Offline
IN
If its a leak at the connection point give the hosa clamps a little tightening and re-check... better yet, get some new heater hose and re-check. If its a core leak, the box needs to drop. On mine ('70E w. AC) it can be done with dash in. Agree the FSM is your friend on this.
Re: heater core removal under the dash [Re: ahy] #1445470
06/01/13 12:20 AM
06/01/13 12:20 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The heater box will come out from under the dash, pull the glove box out. probably take the passenber seat out as well to get some room.
then take the box apart and clean and replace the core, reinstall.
Re: heater core removal under the dash [Re: sthemi] #1445471
06/01/13 04:15 AM
06/01/13 04:15 AM
alaska
69 mayflower Offline
alaska
I removed mine in my 69 Sport Satellite many, many years ago. I didn't remove the passenger seat but that would have made it much easier. The entire heater box will come out as a unit, then you can tear it down and make your repairs. Mine is a A/C heater unit and I'm assuming it should be the same. I was just a dumb kid and managed it, so you should have no problems. It does help to label the electrical and vacuum connections if yours has them. Take pictures also. All those things I didn't do, but it was around 1978 and times have changed.
1969 Plymouth Sport Satellite 383 1990 Dodge W150 plowtruck 318 2012 Dodge Ram 1500 4WD 5.7 HEMI 2012 Dodge Challenger R/T Classic Blackberry Pearl 5.7 HEMI MOPAR- WHAT ALL OTHER CARS WANT TO BE WHEN THEY GROW UP-
