Re: My 1980 D150 Big block swap
[Re: 70Duster440]
#1445415
05/31/14 03:51 AM
05/31/14 03:51 AM
Posts: 440 Marysville, WA
77ProStreet
Marysville, WA
A few more pics after POR 15. [image] [/image] [image] [/image] [image] [/image] Mustang gas tank is next. I was a little premature with my paint cause I have to relocate that x member and weld in brackets to hold gas tank. OH well
[Re: venom107]
#1445421
06/05/14 04:28 AM
06/05/14 04:28 AM
77ProStreet
Marysville, WA
Are you running a spacer for the front wheels? I had to have the rotor hub turned down for the wheels to fit. I still have to modify the dust caps to get the center caps on.
I finally tried those wheels on the front. Looks like I will be getting my rotors turned down too. What a PITA! I tried a 1/4" spacer, but the more I thought about it....just not a good idea. I'll have to look into a stubby dust cover also, I think I've seen them around.
[Re: 77ProStreet]
#1445423
06/11/14 08:09 PM
06/11/14 08:09 PM
77ProStreet
Marysville, WA
I started on my mustang gas tank install, here's a couple pics. I went with the bigger '70 tank, 22 gallon I believe. I took out the existing X member here: [image] [/image] ..and flipped it over and welded it in the back. Now I have a built in mounting surface for the rear of the tank and I'll use some 1.5 or 2" L channel for the front. [image] [/image]
[Re: 77ProStreet]
#1445428
06/13/14 09:28 PM
06/13/14 09:28 PM
Posts: 1,069 Washington State
70Duster440
Washington State
Great timing! Getting ready to do the same thing using a Stang tank on ours. Interested to see what issues, if any, you encounter.
[Re: Golden-Arm]
#1445430
06/14/14 02:38 AM
06/14/14 02:38 AM
77ProStreet
Marysville, WA
So far so good. It may take another week to get back on it, just found out my floor is rotten in my camp trailer it's a 2004 and that's the reason I bought it, newer = no problems, right!?! Now I have to gut the whole front half....PITA!!!! Anyway I'll jump back on the tank and finish up with some pictures.
