1940 ply coupe #1444906
05/30/13 08:54 PM
05/30/13 08:54 PM
Pa. bucks county
cuhemida Offline OP
cuhemida  Offline OP
Pa. bucks county
just wanted to let you all know i just picked up a 1940 ply coupe i'll get some pic's over the weekend and post have a couple of things to do to it then i'll be on the road
Re: 1940 ply coupe [Re: cuhemida] #1444907
06/19/13 02:55 AM
06/19/13 02:55 AM
PA
bbrroowwnn Offline
bbrroowwnn  Offline
PA
I saw it....nice car...I am a friend of Dons....good luck with it....let me know when you guys get it going
Re: 1940 ply coupe [Re: bbrroowwnn] #1444908
06/20/13 12:02 AM
06/20/13 12:02 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Been a lot of weekends we have been waiting to see those pictures. Gene
Re: 1940 ply coupe [Re: poorboy] #1444909
06/21/13 03:24 AM
06/21/13 03:24 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
GENE LET ME POST A FEW OF THEM,., JUST GOT IT UP AND RUNNING TONIGHT,,FOR A 318 IT SOUNDS MEEN,, LUNATI CAM OF SOME SORT, MAY JUST BE A THUMPER CAM,, HAVE A FEW BUGS TO WORK OUT BEFORE WE PUT IT IN GEAR,,,THE MAIN THING IS AS SAID BY THE PREVIOUS OWNER IT RUNNNSSSSSSSS!!!!!!!
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 1940 ply coupe [Re: fstfish66] #1444910
06/21/13 03:25 AM
06/21/13 03:25 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
ANOTHER
2015 cherokee
2013 R/T classic
Re: 1940 ply coupe [Re: fstfish66] #1444911
06/21/13 03:26 AM
06/21/13 03:26 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
FRONT VIEW
2015 cherokee
2013 R/T classic
Re: 1940 ply coupe [Re: fstfish66] #1444912
06/21/13 03:27 AM
06/21/13 03:27 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
INTERIOR CUSTOM MODERN LOOKING DASH
2015 cherokee
2013 R/T classic
Re: 1940 ply coupe [Re: fstfish66] #1444913
06/21/13 03:28 AM
06/21/13 03:28 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
LAST OEN ALL WE HAVE SO FAR,,MORE TO COME AFTER ITS RUNNIGN AND CLEANED UP,,,
2015 cherokee
2013 R/T classic
Re: 1940 ply coupe [Re: fstfish66] #1444914
06/21/13 06:35 PM
06/21/13 06:35 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That needs cleaning up?!?
That is a sharp looking car.
Nothing wrong with a 318 in these old bodies, they can be made to run pretty hard on the street. Gene
Re: 1940 ply coupe [Re: poorboy] #1444915
06/24/13 12:36 AM
06/24/13 12:36 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
GENE WE PICKED UP THE COUPE FROM A GUY THAT TRIED TO DO SOME UP GRADES LIKE 5 YEARS AGO AND COULDNT REALLY DO ANY OF THE WORK HIM SELF,,, CAR HAS BEEN SITTIGN IN A GARAGE IN FRONT OF OPEN WINDOWS AND IS JUST DIRTY AND HAS SOME SURFACE RUST ON SOME OF THE CHROME,,, IT WILL CLEAN UP NICELY,,,STILL HAS ORIGINAL 1940 SUSPENSION STEERING AND BRAKES,,, BUT SUPER SOLID AND CLEAN UNDERNIETH NEVER ANY RUST
2015 cherokee
2013 R/T classic
Re: 1940 ply coupe [Re: fstfish66] #1444916
06/24/13 01:48 AM
06/24/13 01:48 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Neat looking car,I like the downsized grille.Agreed,a 318 can be a good runner.
Re: 1940 ply coupe [Re: RTSrunner] #1444917
06/24/13 02:07 AM
06/24/13 02:07 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
its shocking with the amount of 318 motor laying around that there arent more off the shelf performance parts,,,to my knowledge i dont think there are any off the shelf higher compression pistons available,,,thats where the 318 lacks the most,,,
yes the custom front end work on the 40 coupe looks great
2015 cherokee
2013 R/T classic
Re: 1940 ply coupe [Re: fstfish66] #1444918
06/24/13 02:11 PM
06/24/13 02:11 PM
dogdays Offline
dogdays  Offline
KB makes a decent 318 piston.
R.
Re: 1940 ply coupe [Re: fstfish66] #1444919
06/24/13 11:34 PM
06/24/13 11:34 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Well then, I would have to do a disc brake conversion and master cylinder upgrade, move the front upper shock mount to the frame, to bring the stock suspension and brakes up to modern standards, and drive it. There are a lot of disc brake conversions out there, some of the more recent are adapting rotors from a late model Jeep and keeping the original spindles & hubs, then adding the brackets to hold the calipers. Lots of good info over on the HAMB board. Gene
Re: 1940 ply coupe [Re: dogdays] #1444920
06/25/13 05:15 AM
06/25/13 05:15 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
R.
goood to know thanks
2015 cherokee
2013 R/T classic
Re: 1940 ply coupe [Re: poorboy] #1444921
06/25/13 05:25 AM
06/25/13 05:25 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
shocks already done, i didnt think to look on the hamb,but have u ever heard of the P14/D24 site? a guy over there got some explorer parts out of the junk yard for trial fit, rotors fit the 40s mopar hub, one guy had to d o a little sanding of the hub but no big deal and made a caliper bracket, said he used ford calipers,i guess ford explorer calipers must mount like a GM,, i didnt think about using a jeep rotor,,what kind of caliper do they use do u know?
2015 cherokee
2013 R/T classic
Re: 1940 ply coupe [Re: fstfish66] #1444922
06/26/13 03:36 AM
06/26/13 03:36 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
A lot of guys are using the bolt on GM calipers,they make or buy 3/8" cut plate that bolts to the spindles and the calipers bolt to the plates. I suppose any caliper that attaches easily would work, haven't really kept up on how anyone mounts calipers lately. Gene
Re: 1940 ply coupe [Re: poorboy] #1444923
06/26/13 01:28 PM
06/26/13 01:28 PM
dogdays Offline
dogdays  Offline
Crown Vic/Lincoln rotors are what Scarebird uses. I have a set for my '64Dog, also the matching calipers. Haven't got to the swap yet, I need kingpin bushings first!
R.
Re: 1940 ply coupe [Re: dogdays] #1444924
06/27/13 09:09 AM
06/27/13 09:09 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
R.
thanks for that info i forgot about him should look him up see what he has to offer
2015 cherokee
2013 R/T classic
Re: 1940 ply coupe [Re: fstfish66] #1444925
06/27/13 02:45 PM
06/27/13 02:45 PM
dogdays Offline
dogdays  Offline
I am going to use the larger 1998 - 2002 rotors, Scarebird uses the earllier rotors which will fit a 15" wheel.
2003-and-up are different again, changed the offset of the wheels.
R.
