Gotta Love a Dodge truck- up date
#1444844
05/30/13 04:48 PM
05/30/13 04:48 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I'm on my way to the dump to get rid of some trash, and about 10 miles from home I hear the rear making noise. Sounds like bearings. Well I turned around and limped it home. Every now and then it would grumble loud and start to grab. I would tap the brakes and it would settle down some. Even locked up once. Backed it up and it let go. Got it home and opened it up. WOW completely dry and only 7 rollers fell out. I have an 84 and I think the rears should swap out no problem. I could find the leaks and fix this one but the 84 doesn't leak, has better gears, and a fresh brakes. It just seems easier. Let me know if I'm out in left field.
I have mechanical Aptitude. I can screw up anything.
Re: Gotta Love a Dodge truck
[Re: NITROUSN]
#1444846
05/31/13 01:10 AM
05/31/13 01:10 AM
bboogieart
Lost and Spaced
I don't recall blaming the truck. I was just surprised how far it went, and glad it made it home. Cut what bearings off? There is just pieces of the cages left. I am going to swap out to the better geared 84 rear. thanx for your advice or criticism or what ever that was.
[Re: dogdays]
#1444849
05/31/13 05:56 PM
05/31/13 05:56 PM
bboogieart
Lost and Spaced
You realize it's a full floater. right? But you can have it, I have another to throw in. Just to clarify some, this truck is a rusted piece of scrap metal on wheels. Bought 7 years ago for 350 dollars. It don't owe me a thing and I sure wasn't too concerned on it's well being. Still gonna run it. I am collecting body parts though. Bought a solid, full cab from a member here and a really nice front clip locally. It may have a second life yet. Not sure yet as I also have a 78 1/2 ton that needs a body. I would rather stay with a 70's body on that one though. and the new front clip.
[Re: Pkeel]
#1444852
06/02/13 12:32 AM
06/02/13 12:32 AM
bboogieart
Lost and Spaced
Well, the thing is, I'm going to use my 80's axle. The 76 axle has studs and nuts, not bolts. I will pull a couple bolts and see what you need. It should be available at any hard ware store, shouldn't it? You sure can have the backing plates though. I'll leave it to you to find out if the 76 plate will fit your 80 truck. Maybe some one here can tell us. As for the "you can have it" crack about the axle housing for shortening, I was just kidding. I didn't figure these would ship well.
[Re: bboogieart]
#1444853
07/27/13 07:55 PM
07/27/13 07:55 PM
bboogieart
Lost and Spaced
Been awhile between the rain just after it happened and working through the hot weather. I finally got that 84 rear put under the truck. The newer rear is a dream compared to the deep gear set on the old one. Now it just rolls along at a very comfortable rpm at 55 mph compared to the way it screamed for another gear with the old set. So to sum up I replaced the shocks and u-bolts and re-used the backing plates complete with the new wheel cylinders, brake lines, and 3" brake shoes I installed two years ago. any body need a rear to shorten?
[Re: bboogieart]
#1444854
07/28/13 12:49 AM
07/28/13 12:49 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Are you paying the shipping??? lol
I am truckless..
[Re: 76440]
#1444861
07/30/13 09:06 PM
07/30/13 09:06 PM
bboogieart
Lost and Spaced
I am sure the spindle could be cleaned up, just gotta be careful cutting the bearing races off. Gonna take the cover tomorrow and check the ratios on both. Sure goes down the road nice and the terrible grumbling I though was in the trans or throw out bearing is gone too. I have no further use for it, so I guess I will try to get a couple bucks locally, otherwise it goes in the scrap pile.
