Door Jamb Dome Light Switch Part Number 3 Terminal #1444692
05/30/13 08:20 AM
05/30/13 08:20 AM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
Does anyone know if there is an after market part number for a 3 prong door jamb switch Chrysler OEM number 3488435? Fits a 1972 Roadrunner drivers side door. Look likes the one on the left with big threads.
Re: Door Jamb Dome Light Switch Part Number 3 Terminal [Re: CYACOP] #1444693
05/30/13 08:22 AM
05/30/13 08:22 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I wish ya luck,
Your gonna need it
Re: Door Jamb Dome Light Switch Part Number 3 Terminal [Re: CYACOP] #1444694
05/30/13 08:39 AM
05/30/13 08:39 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I took 2 different switches and combined them to make one for my 71 challenger. It's been 7 years now and I don't remember the part numbers. I do have some pictures somewhere that I will try to find and see if there any help.
Re: Door Jamb Dome Light Switch Part Number 3 Terminal [Re: CYACOP] #1444695
05/30/13 08:53 AM
05/30/13 08:53 AM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
I bought them for my '70 Challenger at drivewire.com. Part number for the two prongs I purchased is ACD6088 - under $10 each. I did a quick search for '72 RR on their site and it says the same part number, two prong.
Check out their site, maybe you can find what you need...
Re: Door Jamb Dome Light Switch Part Number 3 Terminal [Re: Challenger 1] #1444696
05/30/13 12:31 PM
05/30/13 12:31 PM
SW Fla.
CYACOP Offline OP
CYACOP  Offline OP
SW Fla.
If I can figure out how to remove the end that goes on the inside where the terminals are I could build 1 from what I have. I do have one from a 72 New Yorker with the correct 3 hole connector but the threads are too small for what I need, it just falls in the hole in the jamb.I also thought about converting to 2 wire but not sure yet how that will work out by tying 2 of the wires together prior to the switch. I hate to hack up the terminals on the wire harness to do that.
