Limited slip chatter
#1444681
05/30/13 06:54 AM
05/30/13 06:54 AM
Posts: 1,010 Sandy, OR
DART67GT
Sandy, OR
My Ram recently got the diffs serviced. It had one bottle of the friction modifier added. Now when I have driven it enough to warm it up,I get some chatter when turning hard to the left. It doesn't seem to do it on right hand turns. I get no chatter when the truck is cold. Should I add a second bottle of the friction modifier?
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads
2000 Dodge Ram 2500 Quad Cab CTD
Re: Limited slip chatter
[Re: DART67GT]
#1444682
05/30/13 07:46 AM
05/30/13 07:46 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I've got a similar problem on my 72 Road Runner. I've run it with two different sure grips (a cone and a clutch) and it always squeals the tire on a left turn. Never on a right turn. Running a single bottle of friction modifier and wondering if I need to add a second, or if there is some other mechanical issue.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
