MOPAR TECHS-2000 300M LIFTER/ROCKER NOISE, HELP! #144441
11/01/08 09:02 PM
11/01/08 09:02 PM
Westfield, MA
rbrogle Offline OP
super street
rbrogle  Offline OP
super street
Westfield, MA
Here's the deal-
My 2000 300M has 155,000 miles on it. It runs great, but it has developed a bad ticking at between 2400-3200 RPM coming from the top of the engine. The oil is clean, it runs well, but the noise isn't getting any better.
Have any of you Mopar techs (or non Mopar techs!) heard of this. It's the 3.5L V6 engine. I want to fix it and run it for another 150K if I can.
HELP!
Rob '70 Fury III 'vert (GT Clone)was 318 3 on the tree,now 440 automatic '68 300 2 Door HT vinyl/cloth bench '68 Newport Custom 4 Dr. HT, 383/2, FULLY LOADED! '68 New Yorker 4 Door HT, 440/Auto, loaded! 2004 Chrysler 300M Special daily driver
Re: MOPAR TECHS-2000 300M LIFTER/ROCKER NOISE, HELP! [Re: rbrogle] #144442
11/01/08 10:42 PM
11/01/08 10:42 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
Cold and hot? Does it have any coolant leaks? You might have a collapsed lifter or broken valve spring. I would pop the valve covers off and have a look. It may be something minor but turn into something major if you keep driving it.
Re: MOPAR TECHS-2000 300M LIFTER/ROCKER NOISE, HELP! [Re: rbrogle] #144443
11/02/08 02:01 AM
11/02/08 02:01 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'm pretty sure the 3.5L is an overhead cam engine. If you have not replaced the timming belt, I would guess the belt is starting to come apart!
Re: MOPAR TECHS-2000 300M LIFTER/ROCKER NOISE, HELP! [Re: 451Mopar] #144444
11/02/08 12:47 PM
11/02/08 12:47 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
True dat, they are notorious for the water pump going and taking out the timing belt.That can cause an engine (lifter type) noise. Usually you will get coolant on the floor.
Re: MOPAR TECHS-2000 300M LIFTER/ROCKER NOISE, HELP! [Re: 10sec440] #144445
11/02/08 04:47 PM
11/02/08 04:47 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Also check the drivers side cam shaft sprocket bolt.Might be loose or broken.
Leave the gun.......take the Cannoli's....Mike
Re: MOPAR TECHS-2000 300M LIFTER/ROCKER NOISE, HELP! [Re: mike s] #144446
11/05/08 10:59 PM
11/05/08 10:59 PM
Westfield, MA
rbrogle Offline OP
super street
rbrogle  Offline OP
super street
Westfield, MA
Sorry for the delay guys, and thanks for the responses. It had a new belt and water pump at 80K, so this one has about 75K on it. The car has been flawless otherwise. I have a friend looking at it on Sunday, so we'll see what the deal is. There are no coolant leaks anywhere.
Keep the responses coming if there arer any more ideas.
Thanks!
