Will a PCV help condensation in Alum. Blk.?
#1444217
05/29/13 02:28 PM
05/29/13 02:28 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I have driven my car a few miles on the street now and noticed a lot of condensation inside engine and in the oil. I have read that this is common to all aluminum engines, which mine is. Will a PCV help with this? I know that short running time is bad, and the engine does run 180*F plus. If anything a little hotter. Thanks, Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Will a PCV help condensation in Alum. Blk.?
[Re: Hemi Allstate]
#1444218
05/29/13 02:37 PM
05/29/13 02:37 PM
Posts: 43,237 Bend,OR USA
Cab_Burge
I ran two PCV and two breather caps in my aluminum headed iron block to reduce condensation in it Heat rises, water evaporates and condensates when cooled on whatever is the highest(valve covers ) point in the motor
[Re: Cab_Burge]
#1444219
05/29/13 02:39 PM
05/29/13 02:39 PM
Thumperdart
State of confusion
Did you get a hold of Kevin Cab?
[Re: Thumperdart]
#1444220
05/29/13 03:40 PM
05/29/13 03:40 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Are you getting the engine hot at all? I am going to assume you are running a cast aluminum valve cover, this will exaggerate the issue. Although I PCV or something to vent crankcase pressure is a very good idea.
[Re: Hemi Allstate]
#1444222
05/29/13 04:58 PM
05/29/13 04:58 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
I never had an issue like this when I just had a couple of breathers on the valve covers. I have a vacuum pump now though.
[Re: an8sec70cuda]
#1444223
05/29/13 05:46 PM
05/29/13 05:46 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
My vacuum pump always pulls a few ounces of water out of the aluminum block on start up,and when you pop the valve covers are any other part on the engine no condensation at all.Not sure if you can run a vacuum pump on the street but if possible that would be your best bet.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Hemi Allstate]
#1444226
05/29/13 07:55 PM
05/29/13 07:55 PM
Triple Threat
Renton Washington
I don't know either, but I may look into it. Thanks, Mark
You can, certain companies like GZ have no problems with it. http://www.gzmotorsports.com/
Not sure about Aerospace, Star, Moroso or the other brands out there.
[Re: Hemi Allstate]
#1444227
05/29/13 08:00 PM
05/29/13 08:00 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Chip, What temp do you run your engine? Do you avoid short run times ? Thanks, Mark
If you can get the engine up to 215 for a bit before you shut it down it will boil the condensation out... you have to get it up to 212 at least.. then as it sits the temp will climb a little which helps it... you can attach the PCV hose to the base of the carb or the intake(same thing)
[Re: MR_P_BODY]
#1444228
05/29/13 08:56 PM
05/29/13 08:56 PM
moparpollack
Lil Herman
Lil Herman
85086
How are all the aluminum block and head cars not suffering from this? I know hemi valve covers are tall and have a lot of open space that would cause the condensation but, would the material that are made of really cause this problem?
[Re: moparpollack]
#1444229
05/29/13 09:09 PM
05/29/13 09:09 PM
MR_P_BODY
They did suffer from it... thats why they went up to the 195 stat in the cooling system... before they did that they were getting condensation and sludge in the engine
[Re: Mulehead]
#1444231
05/29/13 10:10 PM
05/29/13 10:10 PM
MR_P_BODY
Vacuum Pump on mine
Doesnt look like a street engine to me... most guys I know dont run a vac pump on the street... not saying you cant but it might draw a lot of oil
[Re: MR_P_BODY]
#1444232
05/29/13 11:04 PM
05/29/13 11:04 PM
Posts: 635 mississippi
bentwheel43
mississippi
I don't run mine on the street but it will help cool it down after running when the motor is not running and it helps keep the water out the oil.I got a fitting from Star mech.for the valve cover.
Section 8 Racing We are nuts about racing.
[Re: bentwheel43]
#1444233
05/29/13 11:18 PM
05/29/13 11:18 PM
bentwheel43
mississippi
It sucks good it will suck your hand down to it.I will try a cap on it and try that but it won't let the cool clean air in.The pump is off a 2001 firebird.
[Re: bentwheel43]
#1444234
05/30/13 12:10 AM
05/30/13 12:10 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Shell says that you need 140+ degree oil temps for 1 hour to get rid of the water. Airplane engines are aluminum and have this requirment also. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#1444235
05/30/13 08:22 AM
05/30/13 08:22 AM
Hemi Allstate
Mt. Eden Ky.
As usual a lot of good information here. Some good ideas to look into. I think first off I will change the t-stat. Thanks to all, Mark
[Re: Hemi Allstate]
#1444236
05/30/13 09:30 AM
05/30/13 09:30 AM
an8sec70cuda
Mark...mine usually runs around 180-200 on the street. Just depends on where I'm going and how much highway driving I'm doing since that's where it gets warm. I live way out of town in the sticks, so it isn't a real short trip anywhere, lol. FWIW...I don't recommend a vacuum pump on the street, even though I've had one for the last 5 years on the 'cuda. I've had some issues w/ it, but pulling too much oil isn't one of them. May just be the pump I have...it's an Aerospace Components pump. I'd get the GZ street vacuum pump if I absolutely had to have one for a car that will see street time. If you have standard tension rings, don't bother.
