Which is heavier, Gasoline or water? #1443872
05/28/13 09:23 PM
05/28/13 09:23 PM
fullmetaljacket Offline OP
I'm no Chemical/liquid scientist, but I weighed a gallon of Poland Spring water today and the scale read 8.5 pounds. The Plastic container must not even tip the scales at an ounce or so.
I've always heard that Gasoline weighs 6.5 pounds. Are they both different in weight because of their molecular structures?
Re: Which is heavier, Gasoline or water? [Re: fullmetaljacket] #1443873
05/28/13 09:38 PM
05/28/13 09:38 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Water is heavier. Toss some gas on water and Toss a match...
Re: Which is heavier, Gasoline or water? [Re: Pacnorthcuda] #1443874
05/28/13 09:39 PM
05/28/13 09:39 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
H2O.. oil is also lighter than water....
Coming soon!!!!
Re: Which is heavier, Gasoline or water? [Re: fullmetaljacket] #1443875
05/28/13 09:39 PM
05/28/13 09:39 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
specific gravity of gasoline is around...
Gasoline, Vehicle 60oF 0.739
Specific gravity of water is 1.000
Gasoline will float on top of water...anything with a specific gravity of less then 1.00000 ..floats..
http://www.engineeringtoolbox.com/specific-gravity-liquids-d_336.html
Tony
70 AARCuda Vitamin C
Re: Which is heavier, Gasoline or water? [Re: fullmetaljacket] #1443876
05/28/13 09:40 PM
05/28/13 09:40 PM
AZ.
696pack Offline
696pack  Offline
AZ.
Water weighs 8.44 pounds per gallon and gas is lighter however I don't know the weight. Water is the heavyist liquid on earth other than mercury which I believe is classified as a metal and not considered a liquid.
Re: Which is heavier, Gasoline or water? [Re: fullmetaljacket] #1443877
05/28/13 09:41 PM
05/28/13 09:41 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
All I know is that water weighs 8.34 pounds per gallon,
Re: Which is heavier, Gasoline or water? [Re: Suregrip391] #1443878
05/28/13 09:43 PM
05/28/13 09:43 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
at 60 degrees F...
Tony
Re: Which is heavier, Gasoline or water? [Re: fullmetaljacket] #1443879
05/28/13 09:59 PM
05/28/13 09:59 PM
I guess just like the difference between air and Helium. Air being heavier.
Re: Which is heavier, Gasoline or water? [Re: 70AARcuda] #1443880
05/28/13 10:03 PM
05/28/13 10:03 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
To be pedantic, water is denser, or heavier per unit volume.
Re: Which is heavier, Gasoline or water? [Re: 696pack] #1443881
05/28/13 10:07 PM
05/28/13 10:07 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
There are thousands of liquids heavier than water.
Old, tired, and sometimes broke down. Me, not my car...
Re: Which is heavier, Gasoline or water? [Re: 696pack] #1443882
05/28/13 10:10 PM
05/28/13 10:10 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
.......Water is the heavyist liquid on earth other than mercury......
???? I don't know if there are other qualifiers to this statement or not, but there are a bunch of liquids heavier than water.
Re: Which is heavier, Gasoline or water? [Re: fullmetaljacket] #1443883
05/28/13 10:26 PM
05/28/13 10:26 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Re: Which is heavier, Gasoline or water? [Re: BSB67] #1443884
05/28/13 10:44 PM
05/28/13 10:44 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Not to mention, "liquid" is one of 3 forms of matter that a substance can be. H2O can be a solid (ice) liquid (water) or gas (steam).
And since density changes with temperature you must add a temperature as another qualifier. I have no idea what liquid oxygen weighs per gallon, but I can tell you that it's VERY cold. And at some point, mercury will freeze into a solid just as at some point, iron turns into a liquid.
**Photobucket sucks**
Re: Which is heavier, Gasoline or water? [Re: 70Cuda383] #1443885
05/28/13 11:02 PM
05/28/13 11:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There are four forms of matter, plasma being the fourth.
https://en.wikipedia.org/wiki/Plasma_%28physics%29
Don't be the exception.
Re: Which is heavier, Gasoline or water? [Re: Supercuda] #1443886
05/29/13 01:50 PM
05/29/13 01:50 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Some things "sublime" and skip from solid to gas without ever being a liquid like CO2. However, at a very high pressure and the correct temperature it could also become a liquid.
Re: Which is heavier, Gasoline or water? [Re: Supercuda] #1443887
05/29/13 02:00 PM
05/29/13 02:00 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Where do ghosts/spirits fall into this?
Re: Which is heavier, Gasoline or water? [Re: GTX MATT] #1443888
05/29/13 02:02 PM
05/29/13 02:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
According to Michio Kaku, they could be from another dimension, if they exist.
Re: Which is heavier, Gasoline or water? [Re: fullmetaljacket] #1443889
05/29/13 02:17 PM
05/29/13 02:17 PM
I think race gas is around 6.25 lbs per gallon(7.40 density) , airplane 100 Low Lead is around 6.0 lbs per gallon(5.90) and pump gas in probally close to race gas weight, 7.0 to 7.3 in a gasoline hydrometer I think the U.S.Army use to use 8.5 lbs per gallon of water minus the container weight when figuring what weights you where going to to tote on your back in combat conditions
Re: Which is heavier, Gasoline or water? [Re: fullmetaljacket] #1443890
05/29/13 05:26 PM
05/29/13 05:26 PM
The occaisional water globules in my eddy carb bowl are always on the bottom, that's why I added a drain bung on my new A body gas tank, to deal with that (& switched gas stations)
Re: Which is heavier, Gasoline or water? [Re: Supercuda] #1443891
05/29/13 05:59 PM
05/29/13 05:59 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Do you think that because of their different specific gravities that they might experience time dilation at different rates, keeping the water fresher than gas, particularly if we were able to time travel?
