Hemi alternator pulley #1443869
05/28/13 08:22 PM
05/28/13 08:22 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
What is the correct alternator pulley for a 67 Hemi B Body??
Single groove, double groove??
thanks
Re: Hemi alternator pulley [Re: hemi67] #1443870
05/29/13 02:03 AM
05/29/13 02:03 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
single groove on the alt and use a normal 383 non-ac water pump pulley. Both are not hard to find or expensive
Re: Hemi alternator pulley [Re: hemi70se] #1443871
05/29/13 03:45 PM
05/29/13 03:45 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Thanks for your help. I currently have that 383 non A/C pulley on the water pump, but I have a double groove pulley on the alternator and the alignment is off by just a little. It appears that the Alt. pulley is back just a little bit too far,maybe 3/16 inch, so I am hoping the single alternator pulley will correct the issue.
thanks again.
