Re: Big block First Gen Dakota - What oil pan?
[Re: 76dodgeboy]
#1443677
05/30/13 09:36 PM
05/30/13 09:36 PM
Posts: 2,046 ky.
kenworth_goose
ky.
Just ask Katfish He had a Bigblock in his. First I've heard of needing a different oil pan for the swap. Even for a sb. If that's the case Id just raise the motor to clear
I done a couple of these swaps. I move engine , trans back 2.5 inches and use stock truck pans. Solves a whole lot of problems and gets a bunch of weight off the nose. Just notice how far the engine sets away from the firewall on stock dakotas.
[Re: kenworth_goose]
#1443678
05/30/13 10:22 PM
05/30/13 10:22 PM
Posts: 30 NW Indiana
WeeWillie
NW Indiana
Sorry for the hi-jack, have you found an off-the-shelf header to fit with the engine now moved back? Did you use a motor plate or fab up your own mounts? Thanks in advance.
[Re: savoy64]
#1443680
06/01/13 12:59 AM
06/01/13 12:59 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
the sump area on a dakota oil pan is about 1/2 the size of a regular truck oil pan---for a small block just find the correct oil pan and pick up tube----for a bigblock you need to be a fabricator or know how to find one---either for the oilpan or cutting the firewall and tunnel for clearance....bob
Did you read the above post? No pan fable needed
[Re: WeeWillie]
#1443681
06/01/13 11:10 PM
06/01/13 11:10 PM
Posts: 2,046 ky.
kenworth_goose
ky.
I fab truck brackets welded to the frame, then bolt in with factory engine brackets and mounts. I keep it simple. On the small block stuff you can use dakota headers. On the big block stuff you can use engine swap headers. There no need for high dollar schumacher engine swap kits. The first one I did took me an hour to figure out and weld the brackets.
[Re: savoy64]
#1443682
06/01/13 11:13 PM
06/01/13 11:13 PM
Posts: 2,046 ky.
kenworth_goose
ky.
There is zero need to cut the firewall on either the smaal or big block swap! Plenty of clearance to slide engine, trans. back 2.5 inches on both without ANY major mods.
