instead of going faster went slower (video) #1443300
05/28/13 01:35 AM
05/28/13 01:35 AM
BX, CT, FL.
B1KILLER Offline OP
B1KILLER  Offline OP
BX, CT, FL.
Got rid of radials,put some Hoosier 10/28.
Couldn't figure out why my car wasn't 60'.
Today a friend of mine call me after seeing a pic of my car online,to tell me my front struts had all the preload out of them. Hes correct, I remember now lowering the car when motor was out so it wouldn't sit so high. Going to try putting a lot back in for next outing. Had me some fun at SGMP this weekend.
https://www.youtube.com/watch?v=qnfJwk_ehZw&feature=youtube_gdata_player
Re: instead of going faster went slower (video) [Re: B1KILLER] #1443301
05/28/13 01:47 AM
05/28/13 01:47 AM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
what MPH are you running? it looks quick but there is NO noticeable weight transfer. that's a weird launch in my opinion. either you got very stiff springs (i.e. no weight transfer) or you're not hooking, hard to tell from that video
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: instead of going faster went slower (video) [Re: VincentVega] #1443302
05/28/13 02:33 AM
05/28/13 02:33 AM
BX, CT, FL.
B1KILLER Offline OP
B1KILLER  Offline OP
BX, CT, FL.
I have to put back the preload,I missed up.
138mph in the 1/4, will be better soon.
another video
https://www.youtube.com/watch?v=QxQFJgt-wgI&feature=youtube_gdata_player
Re: instead of going faster went slower (video) [Re: B1KILLER] #1443303
05/28/13 02:51 AM
05/28/13 02:51 AM
That converter sounds pretty loose, it sounds like it up is against the converter off the line for quite a while before the converter locks up and starts pulling the car
Re: instead of going faster went slower (video) [Re: Cab_Burge] #1443304
05/28/13 09:46 AM
05/28/13 09:46 AM
BX, CT, FL.
B1KILLER Offline OP
B1KILLER  Offline OP
BX, CT, FL.
I believe your rite,thats why I also have to go up on my gears.
Re: instead of going faster went slower (video) [Re: B1KILLER] #1443305
05/28/13 10:45 AM
05/28/13 10:45 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
A radial is a faster tire so car should slow down. Only if you are having trouble getting car to hook would a slick be faster. A slick is more forgiving and works with less then perfect rear suspension.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: instead of going faster went slower (video) [Re: 1967dartgt] #1443306
05/28/13 04:14 PM
05/28/13 04:14 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
were they runnin1/4 mi in Ga.?
