Need suggestions for air cleaner solution...
After installing an Edelbrock 600 carb with 1/2" wood spacer on my 74 Cuda which has a 440 and Weiand 8009 manifold, neither my old 3" air cleaner, nor the free Eddy 3" air cleaner (#1223, 14" diameter, 3 3/4 height) gives me enough clearance to close the hood.
Looks like I'm lacking a good inch or so of clearance Clarence ....
Any ideas of what size/kind of air cleaner I can use? I thought about using the free Eddy air cleaner cover and replacing the it's 3" filter with 2" filter
, but not sure if the engine would be air starved or not with the smaller filter....
Any suggestions appreciated!!
