Need air cleaner advice - current one now too tall.... #1443231
05/27/13 11:05 PM
05/27/13 11:05 PM
Lenexa, KS
bs549 Offline OP
super street
bs549  Offline OP
super street
Lenexa, KS
Need suggestions for air cleaner solution...
After installing an Edelbrock 600 carb with 1/2" wood spacer on my 74 Cuda which has a 440 and Weiand 8009 manifold, neither my old 3" air cleaner, nor the free Eddy 3" air cleaner (#1223, 14" diameter, 3 3/4 height) gives me enough clearance to close the hood.
Looks like I'm lacking a good inch or so of clearance Clarence ....
Any ideas of what size/kind of air cleaner I can use? I thought about using the free Eddy air cleaner cover and replacing the it's 3" filter with 2" filter , but not sure if the engine would be air starved or not with the smaller filter....
Any suggestions appreciated!!
Re: Need air cleaner advice - current one now too tall.... [Re: bs549] #1443232
05/28/13 01:52 AM
05/28/13 01:52 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Maybe use a dropped base filter housing?
Re: Need air cleaner advice - current one now too tall.... [Re: Ramrod39] #1443233
05/28/13 01:58 AM
05/28/13 01:58 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
If the drop base doesn't work, maybe the 2" filter and one of those filter lids?
Re: Need air cleaner advice - current one now too tall.... [Re: Ramrod39] #1443234
05/28/13 08:56 AM
05/28/13 08:56 AM
Lenexa, KS
bs549 Offline OP
super street
bs549  Offline OP
super street
Lenexa, KS
Thanks. Have an electric choke on the carb, so can't go much lower of a dropped base than the free eddy cleaner I have now.
Re: Need air cleaner advice - current one now too tall.... [Re: bs549] #1443235
05/28/13 10:54 AM
05/28/13 10:54 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If you switch to a 2" filter and you have a drop base you need to look at how much space you have between the air cleaner top and the air horn of the carb , it can cause an airflow issue .
Re: Need air cleaner advice - current one now too tall.... [Re: JohnRR] #1443236
05/28/13 11:00 PM
05/28/13 11:00 PM
Lenexa, KS
bs549 Offline OP
super street
bs549  Offline OP
super street
Lenexa, KS
yep...it looks like i'll have 1 1/4 of clearance, which may not be enough Short of using a sawsall on the hood (just joking), not sure what options I have left...
Re: Need air cleaner advice - current one now too tall.... [Re: bs549] #1443237
05/28/13 11:07 PM
05/28/13 11:07 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Spacers between the k member and body, And maybe switch to a Holley Maybe a Holley is shorter. A 600 is pretty small for a 440 anyway , unless your engine is totally stock.
Re: Need air cleaner advice - current one now too tall.... [Re: bs549] #1443238
05/28/13 11:13 PM
05/28/13 11:13 PM
IN
ahy Offline
ahy  Offline
IN
Eddy has a moderate drop base 14x3 air cleaner. Its available at parts stores and not too expensive. I'm running one on a flat hood BB with M1 manifold. It may clear the choke on yours - worth a try. You can probably return it if it doesn't fit. Summit has all manner of drop bases but many are expensive.
Re: Need air cleaner advice - current one now too tall.... [Re: ahy] #1443239
05/29/13 10:52 PM
05/29/13 10:52 PM
Lenexa, KS
bs549 Offline OP
super street
bs549  Offline OP
super street
Lenexa, KS
Yep...the free Eddy one is a drop clearance 14x3 that ends up being too tall. Thanks all for the suggestions (and any more that are out there)
Update! Found a Mr. Gasket 14x2 filter at O'Reillys and replaced the 14x3 Edelbrock one...gives enough clearance with about 3/4" to spare!
