Re: Stalling problem
[Re: moparcanuk]
#1443183
05/27/13 11:07 PM
05/27/13 11:07 PM
RapidRobert
Take out the idle mixture screws out of the carb (count the # of turns to lightly seated to easily return them to their original position(s). Fit one of those thin red straws to the nozzle on a can of starting fluid. shoot a healthy 2 or 3 second blast into each carb mixture hole then replace the idle mixture screws. Gasahol (10% ethanol) will also act like that. Check reluctor gap if electronic ign but you said stock so I'm assuming points.
