Anyone use a flex-hone ..? #144300
11/01/08 04:36 PM
11/01/08 04:36 PM
Florida STAYcation
dOrk ! Offline OP
The village idiot's idiot
dOrk !  Offline OP
Florida STAYcation
You know those dingle-berry hones .... what "grade" would you give them?
Re: Anyone use a flex-hone ..? [Re: dOrk !] #144301
11/01/08 05:38 PM
11/01/08 05:38 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I use one but they are not a honing hone. They are more of a glaze breaker and remove very little material.
Re: Anyone use a flex-hone ..? [Re: MoparforLife] #144302
11/01/08 05:41 PM
11/01/08 05:41 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Exactly, not even a hone.
Re: Anyone use a flex-hone ..? [Re: Challenger 1] #144303
11/01/08 06:04 PM
11/01/08 06:04 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
i've used them before, probably will on my 360 that has a couple thousand miles before putting it back together.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Anyone use a flex-hone ..? [Re: GoodysGotaCuda] #144304
11/01/08 06:17 PM
11/01/08 06:17 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I have used them before and they work well as a gl;ase braker
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Anyone use a flex-hone ..? [Re: 340SIX] #144305
11/01/08 09:35 PM
11/01/08 09:35 PM
I use one after rigid stone honing for a plateau finish.
Re: Anyone use a flex-hone ..? [Re: RapidRobert] #144306
11/01/08 11:16 PM
11/01/08 11:16 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Robert,
What grit do you use, speed and stroke?
Re: Anyone use a flex-hone ..? [Re: Snoopy] #144307
11/02/08 12:15 AM
11/02/08 12:15 AM
I am not sure as I borrowed it from a buddy quite awhile back when I did my 360 but it was a grit for moly rings & I called flexhone & asked them for the drill speed & # of strokes & how fast to stroke it. They remove virtually no material & smooth out even more the finish from the rigid hone. and you might peruse this site. "breakin secrets" article at www.mototuneusa.com
Re: Anyone use a flex-hone ..? [Re: RapidRobert] #144308
11/02/08 12:32 AM
11/02/08 12:32 AM
Snoopy Offline
Snoopy  Offline
Thanks, I will check it out.
I have used flex-hones in the past to debur the ports in 2 stroke motorcycle cylinders. Nothing works better.
