Replaced ignition switch, in 70 cuda 4sp.(Not tumbler) but noticed that the key will not turn backwards to the accessory position. The other positions are OK. Any ideas? Need a new tumbler? Corrosion maybe? I don't remember if it worked before I removed the column, but while its out I would like to solve it.
John T in CT
