TCI aluminum deep pan leaking - Part 2 Update #1442530
05/26/13 10:13 PM
05/26/13 10:13 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I put on a new gasket with Permatex High Tack gasket sealer, on all four sides. Followed directions to the letter. Drove the car a short way today. Pan is leaking. I checked the blots which were loose by about a 1/4 turn to re-tighten them. Should I use the Red or Blue Permatex threadlocker on the bolts?
This is getting old.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442531
05/26/13 10:53 PM
05/26/13 10:53 PM
Easton, Minnesota
gpuller Offline
gpuller  Offline
Easton, Minnesota
Sorry I didnt get in on part 1 of the pan leak saga.
I had pan sealing troubles and went this route. No more leaks.
Go to the dealer and get a reusable gasket for a Ram pickup they used the same gasket as a 727. P/N 2464324AC retail of around $15.60 Gaskets are a hard plastic with silicone bead on both sides to seal. No sealer is needed on the gasket. The hard plastic prevents over tightening the pan bolts and possibly causing the gasket to squish.
Re: TCI aluminum deep pan leaking - Part 2 [Re: gpuller] #1442532
05/27/13 02:20 AM
05/27/13 02:20 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
That will be the next gasket I'll use if this one leaks again after I find a way to keep the bolts tight. I got a fel-pro gasket, a new one again, and put the high tack gasket sealer on all four surfaces. Let it dry to a tacky touch. Installed pan. Didn't put any fluid in for over 24 hours. Ran the car a few miles, got home, no leakes, and checked the bolts. They were ever so slightly loose. Tightened them again. Drove a few miles today, got home and pan was leaking. Bolts were loose again. Tightened them again! Drove a few miles again, got home no leaks. Checked bolts, they were loose again!! About maybe an 1/8 of a turn to tighten them except two that took about a 1/4 turn to tighten them. Don't know why the bolts keep coming loose so I want to try the Blue Threadlocker. Hopefully that will keep the bolts tight and the pan from leaking.
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442533
05/27/13 02:23 AM
05/27/13 02:23 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
P/N 2464324AC
that should be the only gasket you use...and they are reusable too...
Tony
70 AARCuda Vitamin C
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442534
05/27/13 08:21 AM
05/27/13 08:21 AM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Are you positive its the pan leaking?
I only ask because I thought my cast pan wasn't sealing only to find out it was my dipstick tube o ring. I needed to install a new o ring with some rtv smeared on it to stop the leak.
Shift seals are also another potential leak source that makes it look like its a pan leak.
Re: TCI aluminum deep pan leaking - Part 2 [Re: MPerry] #1442535
05/27/13 11:52 AM
05/27/13 11:52 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I asked him that on his other post and he said it was the pan for sure.
Re: TCI aluminum deep pan leaking - Part 2 [Re: 70AARcuda] #1442536
05/27/13 11:58 AM
05/27/13 11:58 AM
North Central Florida
E
eightlitermopar Offline
E
I also had a TCI pan that I finally got to seal. I soon found out I had a bad casting and it was leaking THROUGH the pan. 1 little pinhole.
I returned that pan, got another, used the gasket mentioned and used lock-washers on the bolts. That seemed to do it.
eightlitermopar
Mopar or no car
Re: TCI aluminum deep pan leaking - Part 2 [Re: eightlitermopar] #1442537
05/27/13 12:48 PM
05/27/13 12:48 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I looked carefully around the trans to see if the fluid could be coming down from there, just to make sure. I looked for a defect in the pan too. Nope, it's coming out of between the pan and the trans through the gasket area. Above the pan it's dry.
I've come to the conclusion that it's because the pan bolts keep coming loose. Since no one answered, I guess it's the Blue Threadlocker I'll try. Red seems a little much.
Re: TCI aluminum deep pan leaking - Part 2 [Re: 70AARcuda] #1442538
05/27/13 12:50 PM
05/27/13 12:50 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
P/N 2464324AC
If the Blue Threadlocker doesn't work keeping the pan bolts tight, I'll be trying that gasket for sure.
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442539
05/27/13 01:15 PM
05/27/13 01:15 PM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
How loose are the bolts in the treads of the trans case ?.... OTHER THAN getting some of those nylon inserted bolts(they have been used on some of the B/RB and Hemi engine oil pans) .... I would try a simple lite lock washer....
Re: TCI aluminum deep pan leaking - Part 2 [Re: BeEtLeJuIcE !] #1442540
05/27/13 02:58 PM
05/27/13 02:58 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Sorry, Doc, I don't understand what you are trying to tell me.
The bolts for the pan have lock washers.
The trans is fine.
No plastic anywhere.
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442541
05/27/13 04:12 PM
05/27/13 04:12 PM
md
mopars4ever Offline
mopars4ever  Offline
md
If all fails this stuff will work. Makes getting the pan back off tough though. You can try Permatex The Right Stuff Gasket Maker
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442542
05/27/13 05:04 PM
05/27/13 05:04 PM
Florida STAYcation
Florida STAYcation
The trans is fine.
JUNKster ... show us a pic of those bolts. You have never seen those ny-lock bolts ?
Re: TCI aluminum deep pan leaking - Part 2 [Re: BeEtLeJuIcE !] #1442543
05/27/13 05:22 PM
05/27/13 05:22 PM
Florida STAYcation
Florida STAYcation
HERE is a ny-lock bolt with a captured washer ....
Re: TCI aluminum deep pan leaking - Part 2 [Re: BeEtLeJuIcE !] #1442544
05/27/13 06:27 PM
05/27/13 06:27 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Easier and probably cheaper to just use blue locktite!
Re: TCI aluminum deep pan leaking - Part 2 [Re: MPerry] #1442545
05/27/13 06:30 PM
05/27/13 06:30 PM
Florida STAYcation
Florida STAYcation
mBerri ....I would worry about pulling the threads OUT OF the trans case ....
Re: TCI aluminum deep pan leaking - Part 2 [Re: BeEtLeJuIcE !] #1442546
05/27/13 06:38 PM
05/27/13 06:38 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Pulling with blue locktite???
Re: TCI aluminum deep pan leaking - Part 2 [Re: BeEtLeJuIcE !] #1442547
05/27/13 11:28 PM
05/27/13 11:28 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
The trans is fine.
Doc, never seen those before.
Would those work better than the bolts that came with the pan and Permatex Blue Threadlock, Locktite, Locktight? That one.
Re: TCI aluminum deep pan leaking - Part 2 [Re: Junky] #1442548
05/27/13 11:49 PM
05/27/13 11:49 PM
Florida STAYcation
Florida STAYcation
That pic is what I pulled up on a Bing search ... the OEM Mopar ones were a yellow or white nylon insert. And I would not bet my life on it ... but I think the OEM used those on the windage tray motors only .... because of the two gaskets and the thickness of the tray....
I say either get those special bolts OR use some quality RTV on the bolts going into the case. ANY of that locklite ....I would worry about it fugging-up the alum threads on the case ...if you ever had to pull the pan off again.
Re: TCI aluminum deep pan leaking - Part 2 [Re: BeEtLeJuIcE !] #1442549
05/28/13 12:02 AM
05/28/13 12:02 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Come on??? Do pan bolts really come loose or does the gasket shrink and the bolts need tightening? I would tighten and paint mark them and drive it. My bets are junk gaskets or a leak from somewhere else.
