Re: 383 engine mounts
[Re: Jeremiah]
#144254
11/18/08 06:21 AM
11/18/08 06:21 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
yup, as far back as you can, because that's a lot of weight to have sitting over the front suspension, and certainly does not help handling.
**Photobucket sucks**
[Re: 70Cuda383]
#144255
11/29/08 09:37 PM
11/29/08 09:37 PM
Posts: 199 SE Wisconsin
49wayfarer
SE Wisconsin
Alright, got some plates in where the mounts will be, firewall is cut, so now I got all kinds of room. Question I got now is how high should I mount the engine, I don't have a bellhousing yet, so I can't quite figure out the drivetrain angles. Heres some pics, first is some mounts I made, 3/8" plate with DOM tubing and bushings, planning on mounting them to the flat plate I had to weld seen in the 2nd photo. Last one, if I can ppost them all, shows where I have it set, too low, the mounts would be higher than the stock ones I plan to connect to. Hope you can understand my plan.
[Re: 49wayfarer]
#144258
11/30/08 10:55 AM
11/30/08 10:55 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Some guys are true geniuses. They can visualize every little thing and plan six steps ahead. Me, I'd have to have a fully dressed motor/trans to mock up. I'd have to stare at each part that unbolts, to make sure the bolts can be reached and the part can be removed. I'd also have to study the angles, exhaust clearance, where the fluids drain, etc. Guess I'm slow... You can go with a big pipe that will fit into the bearing saddles to get an idea of the driveline angles. The old FED builders did this to align the drivelines. http://www.condercustom.com/ATF/purgatory/chassisbook.html
[Re: RodStRace]
#144259
11/30/08 12:27 PM
11/30/08 12:27 PM
Posts: 19,355 north of coder
moparx
when i started on my humpback biuld, i wanted the engine high enough for ground clearance, but lo enough to fit in with what i had in mind for the project. i started out by locating the engine side-to-side, then offsetting it to the passenger side 1/4". this was done using the headders i was planning to use, so space was at a premium. i then leveled it side to side. then , leveled the intake flange at the percieved/expected ride height. then, just for fun, tried different intakes to check carb levels front to back. i discovered there were some differences, so i compromised at a 2* downward slope. this was so when at the track, the carb base would be level on acceleration. then i just made cardboard patterns to locate everything making enough clearance as needed for the steering shaft ,starter, etc. at the same time, i used a gutted trans case to fab the trans mount at the same time. oh, by the way, i'm still not on the road yet......
[Re: 76dodgeboy]
#144264
12/01/08 12:53 AM
12/01/08 12:53 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
Have you looked into using The truck mounts from the 70-80s trucks?
A couple months ago we got our hands on a 46 Nash sitting on a 68 Chevy Frame. A neighbor gave us a 1986 Dodge van (10K on a rebuilt 360) that the body was hammered on. We reefed the 360, I took a zip cut and buzzed the brackets off the frame, and bolted them back to the engine. Set it down into the Nash and started marking/trimming the frame brackets till they matched the frame, and got a little busy with the molten metal attaching device. Worked like a charm and only took a couple hours...
2 Demons...no, not my kids!
[Re: RodStRace]
#144265
12/01/08 02:39 AM
12/01/08 02:39 AM
Posts: 1,295 Hawley, Texas
shinnery
super street
super street
Hawley, Texas
I wonder what happened to page 359 of that book? The link skips from 358 to 360. Still pretty interesting though, Bryce
Every electronic device is manufactured with smoke stored deep inside...
only a true genius can find a way to set it free.
The most terrifying words in the English language are: "I'm from the government and I am here to help!"
